Thread: AC compressor voltage?
Results 1 to 14 of 14
Threaded View
  1. #11 Re: AC compressor voltage?
    Denver
    Check to see if you have resistance across the compressor coil.
    The compressor's only electricity (power wise - there might also be a lower current pressure switch) is a solenoid based clutch that engages when powered by the relay. If the coil is bad, it will mosty likely be an open circuit at the compressor itself.
    I imagine there is little more than a two-pole weatherpack connector @ the coil. Take off the plug and see what resistance you have across the terminals (compressor side not wire side). If it's infinite, you've found your problem: the coil has failed and needs to be replaced. From what I understand, it's relatively simple to fix.
  1. No Voltage at PCM
    By tdenstedt in forum Introductions/Noob Questions
    Last Post: 04-22-2011, 09:08 AM
  2. Low Voltage
    By Wakeboy1337 in forum General Tech Discussion
    Last Post: 02-12-2011, 03:24 PM
  3. Low Voltage Light
    By GreenPrix99 in forum General Tech Discussion
    Last Post: 12-11-2009, 10:12 PM
  4. HID and DRL low voltage Ficker
    By massivesystem in forum Visual/Body Modifications
    Last Post: 04-17-2009, 02:00 PM
  5. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
