Thread: AC compressor voltage?
Results 1 to 14 of 14
  1. #1 Re: AC compressor voltage?
    SE Level Member Pontiac99GTP's Avatar
    Dyer
    Ok I just wanted to make sure the reason there is no voltage at the compressor connection is because the system is low before I start chasing in the direction.
    So I bought the high/low side gauge set and the refridgerant. I was able to get the low side to 45psi but the high side only went to 50psi. The compressor still wouldn't kick on. Will the high side increase once the compressor decides to turn on and cycle the freon through the system? Or how does that work?
  2. #2 Re: AC compressor voltage?
    At 45psi the low side is higher than it needs to be, and the compressor should have kicked on.
    Did you set the AC to on and max cold when you tried this?
  1. No Voltage at PCM
    By tdenstedt in forum Introductions/Noob Questions
    Last Post: 04-22-2011, 09:08 AM
  2. Low Voltage
    By Wakeboy1337 in forum General Tech Discussion
    Last Post: 02-12-2011, 03:24 PM
  3. Low Voltage Light
    By GreenPrix99 in forum General Tech Discussion
    Last Post: 12-11-2009, 10:12 PM
  4. HID and DRL low voltage Ficker
    By massivesystem in forum Visual/Body Modifications
    Last Post: 04-17-2009, 02:00 PM
  5. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
