Thread: Hvac 2000 gtp
Results 1 to 8 of 8
  1. #1 Hvac 2000 gtp
    Feb 2010
    Wichita
    My car is equipped with the dual zone HVAC system. The passenger side blows cool air in the A/C mode and the drivers side blows warm air. How is this issue repaired. I have done the following. I have also noticed the volume of air is much less than when new. I also have noticed that the digital thermometer reads 68 or less when it is HOT as Hati outside.
    1) verified that the AC compressor is actually working - it is
    2) verified Gas levels and head pressure.
    3) revomed Glove box liner and verified the damper is moving - I think it works - I do see movement in the recirculator damper
    4) Fan is running like a top
    Help is most appreciated.
  2. #2 Re: Hvac 2000 gtp
    Wish I was replying with an answer but I actually have the same symptoms with the warmer driver air and cooler passenger air. Any ideas?
  3. #3 Re: Hvac 2000 gtp
    blend door?
  4. #4 Re: Hvac 2000 gtp
    Daytona Beach FL
    blend door?
    I have dual zone and the same problem in a 2001 GTP (pic below). Cold air out of passenger side and warm on drivers side.
    I have read that it is the blend door on a few posts but what do I do to fix it.
    2001 Grand Prix GTP - K&N CAI, Everything else stock
    1995 Formula Firebird - Too Many Mods to list
    www.formulaw66.cz28.com
  5. #5 Re: Hvac 2000 gtp
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    for low air flow also consider changing the cabin air filter.
  6. #6 Re: Hvac 2000 gtp
    Feb 2010
    Wichita
    I took it to the shop for repair. It turned out that the high pressure service valve was leaking causing low freon levels. The shop replaced the service valve added freon and the problem went away. Since it is a dual zone system there are 2 coils. The freon lost its affect before it got to the drives side.
    I also changed the cabin filter which improved the amount of air passing through the system.
    This is per the mechanic that fixed it after 150 buck.
    Now it need to know where the ambient air temp sensor is located. I have the replacement part but no idea where to look.
  7. #7 Re: Hvac 2000 gtp
    GT Level Member 99GPGTP's Avatar
    Rome GA
    i curently have a 99 gtp and it will do the same thing but only when the freon level gets low (Leaking a/c compresspor on my car). if your talking about the outside ambient temp sensor. its located behind the front bumper
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  8. #8 Re: Hvac 2000 gtp
    Daytona Beach FL
    Quote Originally Posted by aubry118 View Post
    This fixed my problem too. Warm air on drivers side. Had it charged up they found the valve leaking. They replaced the valve filled it up works great. I would start with having it checked before you replace anything.
  1. HVAC troubles
    By ajramos26 in forum General Tech Discussion
    Last Post: 04-19-2011, 08:56 PM
  2. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  3. HVAC Controls
    By Brads01GP in forum General Tech Discussion
    Last Post: 03-08-2010, 11:49 PM
  4. HVAC help
    By 3800SE in forum General Tech Discussion
    Last Post: 03-07-2010, 07:02 PM
  5. 04 hvac
    By Scott Francis in forum Introductions/Noob Questions
    Last Post: 10-16-2009, 03:36 PM
