Thread: Oxygen sensor queston.
Results 1 to 5 of 5
  1. #1 Oxygen sensor queston.
    Donating Users
    NorCal
    I'm getting 0141 and 0135, both bank 1, sensors 1 and 2.
    What causes these errors?
    Bad gas? Water?
    Thanks!
  2. #2 Re: Oxygen sensor queston.
    DTC P0135 HO2S Heater Performance Bank 1 Sensor 1
    DTC P0141 HO2S Heater Performance Bank 1 Sensor 2
    Could be wiring, ground, corrosion in connection, or a bad sensor.
  3. #3 Re: Oxygen sensor queston.
    Donating Users
    NorCal
    Thanks Matt!
    Can one bad sensor cause another to go bad?
    I was on vacation 2 years ago and an error lit up. It came on soon after filling up the tank.
    After the next fill up, it went off.
    Can bad gas dirty up the sensors, causing an error?
  4. #4 Re: Oxygen sensor queston.
    http://www.grandprixforums.net/websi...C/1997-L36.pdf
    O2S Heater Circuit
    Malfunction (Bank 1,
    Sensor 2)
    P0141
    This DTC determines if
    the O2 sensor heater is
    functioning properly by
    monitoring the amount of
    time necessary for the O2
    sensor to become active
    after start - up.
    The elapsed time to obtain 0.150V
    from the mean O2 bias voltage.
    *Time based on table: Time vs Start
    Up Coolant Temp.
    ECT < 35C
    IAT < 35C
    ECT-IAT 6C
    Avg MAF < 20 gps
    From cold start to a maximum
    time of 330 seconds.
    *Time determined by table.
    once per key cycle
    DTC Type
    B
    Could be failing sensors by the description above.
    GM (AC Delco) sensors are the best ones.
    But pricey.
    Denso's are a less expensive but comparable option.
  5. #5 Re: Oxygen sensor queston.
    Donating Users
    NorCal
    Thanks again.
  1. Oxygen sensor queston.
    By ckrummy in forum General Tech Discussion
    Last Post: 07-31-2010, 07:55 PM
  2. downstream oxygen sensor replacement help!
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 08:41 PM
  3. Oxygen Sensor
    By BwolfGT in forum Off Topic Discussion
    Last Post: 11-21-2009, 05:44 PM
  4. After cat oxygen sensor installation.
    By English John in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2009, 04:48 AM
  5. oxygen sensor
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 06:20 PM
