Thread: AC Leak!?
Results 1 to 20 of 26
  1. #1 AC Leak!?
    Banned
    CT
    Okay so last summer my A/C wasn't working so I filled it... It worked (was late summer) until it wasn't needed anymore. Well it was hot out today annnndd the A/C didn't work. So I picked up a can of 134 and a can with UV Dye in it. I put it in, A/C works great. After it got dark I broke out the blacklight. The spots where I dripped the refrigerant were HIGHLY visible, however there was no leaks that I could see.
    Any ideas!? Should I get under the car or look under the dash? I mean how many places could this stuff leak out of?
  2. #2 Re: AC Leak!?
    theres a crap load of places it could leak from,
    all the lines and fittings
    the condenser
    the accumulator
    the conpressor
    the evaporator
    just run it for a couple days and then check everything and everywhere all of and see what you can find
    SMGPFC Member #10
  3. #3 Re: AC Leak!?
    Waukesha, WI
    most likely an oring failed, theyre at every connection on the system.
    both my gt, and gtp the compressor had an internal problem, lost refrigerant. all connections dry thought.
    food for thought
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  4. #4 Re: AC Leak!?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Get it up in the air and check the pump, too. The compressors have a tendency to get a leak where the two halves are put together.
    Don't forget to check your carpet on the passenger side, too, in case the evaporator is leaking on the inside.
  5. #5 Re: AC Leak!?
    Banned
    CT
    If the compressor is leaking is there a way to fix it without needing to buy a new one?
  6. #6 Re: AC Leak!?
    Apr 2009
    Probably not an economical way to do so. I wouldn't worry about it yet, until you find the dye leaking out. It could be as simple as one of the o-ring washers, like was already mentioned.
  7. #7 Re: AC Leak!?
    Waukesha, WI
    a reconditioned compressor is 200ish $
    RayRay
    92 Turbo miata
    02 lexus is300
  8. #8 Re: AC Leak!?
    Apr 2009
    I sold a newly remanufactured Four Seasons (warranty) for about $65 a few months back.
  9. #9 Re: AC Leak!?
    With a name like SnowFlake, one would think you are a cool character who wouldn't need AC.
  10. #10 Re: AC Leak!?
    Banned
    CT
    To the contrary... I'm gonna melt this summer if my AC stops working.
  11. #11 Re: AC Leak!?
    Waukesha, WI
    wuss,
    RayRay
    92 Turbo miata
    02 lexus is300
  12. #12 Re: AC Leak!?
    Denver
    Recharge for a bandaid?
  13. #13 Re: AC Leak!?
    Apr 2009
    Expensive bandaid for something that may only last a few days, at best. Find the leak and you may have more than a decade before you have to worry about it again.
  14. #14 Re: AC Leak!?
    Waukesha, WI
    a shop shouldnt recharge if theres a known leak FYI
    RayRay
    92 Turbo miata
    02 lexus is300
  15. #15 Re: AC Leak!?
    Banned
    CT
    I'm gonna check it again with a blacklight tomorrow night, the A/C stopped working again today... and those refill cans are ****ing expensive now. I uesd to be able to pick up 3 of them for about $14. Now it's $13 for one.
  16. #16 Re: AC Leak!?
    Waukesha, WI
    yepp car companys came out with a new refrigerant, so they want to phase out R134a
    RayRay
    92 Turbo miata
    02 lexus is300
  17. #17 Re: AC Leak!?
    Topeka, KS
    Quote Originally Posted by redlinepontiac View Post
    Ha my truck still ran on r12 when i sold it 5 years ago. R12 was cheap but hard to find.
    I bought my last compressor from a Yard 5 years ago out of a Bonne. It's ran like a champ till this year Last year i'd have to fiddle with the plug to make it turn on until i put dielectric grease on the plug. This summer the damn thing won't turn on.
  18. #18 Re: AC Leak!?
    GT Level Member sic6's Avatar
    san marcos, tx
    Make sure the schrader valves on the lines are not leaking. Also the compressor is notorious for leaking from the center sections. Run the system and spray all the connections with soapy water. If you still can not find the leak the best way to find it is to evacuate the system then charge it with nitrogen. I have used this method numerous times and found its the best and fastest way to find leaks.
  19. #19 Re: AC Leak!?
    dirty fittings, hoses and what not usually indicates a leak too, my last truck the a/c would leak at this valve with a wire connection that was a top the box on the fire wall, when i saw it getting greasy looking i would wipe it off and turn it 1/2 a turn to tighten it up. try looking for dirty fittings.
  20. #20 Re: AC Leak!?
    Banned
    CT
    Well I put the light up under the car and saw the neon green fluid leaking from the bottom of the compressor...
  1. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  2. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
  3. Oil leak!!!!!
    By musiknjoyr in forum General Tech Discussion
    Last Post: 02-02-2010, 12:15 AM
  4. Vac leak?
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2009, 07:24 AM
  5. s/c leak
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2009, 06:30 PM
