Thread: fluctuating idle, already clean/ inspected everything
Results 1 to 9 of 9
  1. #1 fluctuating idle, already clean/ inspected everything
    May 2011
    schererville, IN
    I recently got a '96 grand prix with a 3100 and 200K+. When idling revs go from 500-2000, up then down, almost dies, then it saves it self over and over. I cleaned the maf, cleaned the tb, new IAC, helped a tiny bit, but not too much. Then when i leave the in the morning, when i hit the accelerator, the car will die unless i keep my foot on the gas, but after a minute that goes away and the car drives normally. Could this be a Cam problem or a timing problem?
    Thanks
  2. #2 Re: fluctuating idle, already clean/ inspected everything
    have you checked the ect sensor?
    and have you tried pulling any codes form it?
    SMGPFC Member #10
  3. #3 Re: fluctuating idle, already clean/ inspected everything
    May 2011
    schererville, IN
    i scanned my codes and it's just for my bad speed sensor, when inspecting the ect sensor, what should i look for, and can it be cleaned?
  4. #4 Re: fluctuating idle, already clean/ inspected everything
    Kansas
    Sounds like a possible crank positioning sensor problem.
  5. #5 Re: fluctuating idle, already clean/ inspected everything
    ^thats where i was going next, it could be anyone of like 10 senors, just start unpluging them one at a time and see what happens
    SMGPFC Member #10
  6. #6 Re: fluctuating idle, already clean/ inspected everything
    May 2011
    schererville, IN
    alright, i'll check it out next time i get a chance today, i'll let ya know what goes down
  7. #7 Re: fluctuating idle, already clean/ inspected everything
    Kansas
    Have you sprayed carb cleaner around engine while it's running? Possible vac leak as well.
  8. #8 Re: fluctuating idle, already clean/ inspected everything
    just thought about it,,,
    does it run alright when you drive it and give it gas or does it do this all the time?
    SMGPFC Member #10
  9. #9 Re: fluctuating idle, already clean/ inspected everything
    May 2011
    Washington
    I have a 99 GT and had the same idle problem. It was fuse #21 IGN1UH.
    Repaced the fuse, cured the problem.
  1. Went out to get my vehicle inspected and came home with this....
    Last Post: 09-20-2012, 09:59 PM
  2. Question about a fluctuating idle in a Grand Prix GT-3.8
    By nickdemio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-27-2011, 11:22 AM
  3. xp cam fluctuating rpm
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2011, 12:14 AM
  4. Fluctuating RPMs 05 GP
    By NegativeOne13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2011, 01:19 PM
  5. belching black exhaust, fluctuating Idle
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2010, 11:07 AM
