Thread: 2004 GP Blower Issue
Results 1 to 10 of 10
  1. #1 2004 GP Blower Issue
    SE Level Member coachbobby's Avatar
    Apr 2011
    Paragould, Arkansas
    My 2004 GP heat and a/c both work, but air only comes thru the vents when the car is moving. Come to a stop light, no air thru vents. Any ideas on where to start??
  2. #2 Re: 2004 GP Blower Issue
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    blower motor?
    For all your 3800 needs:
  3. #3 Re: 2004 GP Blower Issue
    Apr 2011
    Paragould, Arkansas
    I was set to replace the blower motor and it started working. Worked for about 3 days and now it stopped again. Anyone have suggestions??
  4. #4 Re: 2004 GP Blower Issue
    Banned
    Apr 2011
    wv
    resistor perhaps?
  5. #5 Re: 2004 GP Blower Issue
    SE Level Member jpdubrall84's Avatar
    LeMars, IA
    Yea, could be the resistor in the fan switch. Hook a volt meter up to the wire side of the connection to the motor (the wire coming from the switch) and slowly turn the switch from off to high. Test it in Ohms to see if there are any opens in the resistor, and the resistance should go down as you get to higher speeds. I'm unsure of what the readings should be though. Can't help you there.
    My car is not stock....It's an empty canvas for a work of art.
  6. #6 Re: 2004 GP Blower Issue
    Apr 2011
    Paragould, Arkansas
    Resistor in the fan switch. This would be in the dash, correct?
  7. #7 Re: 2004 GP Blower Issue
    MA
    There is a resistor next to the blower motor
  8. #8 Re: 2004 GP Blower Issue
    Apr 2011
    Paragould, Arkansas
    Found it. Ordering one Monday.
  9. #9 Re: 2004 GP Blower Issue
    Indianapolis
    if you have a junk yard near you, try to find one there and save some money
  10. #10 Re: 2004 GP Blower Issue
    Apr 2011
    Paragould, Arkansas
    Bought a resistor for $54. Few minutes later, had it on and working good! Thanks for the advice everyone! Glad my A/C was working today, it was 99 degrees here in Paragould, Arkansas
  1. 2006 blower motor issue: TSB?
    By TexasGP in forum General Tech Discussion
    Last Post: 04-03-2011, 06:39 PM
  2. blower issue
    By dave2002GP in forum General Tech Discussion
    Last Post: 01-20-2011, 02:11 PM
  3. 2004 Pontiac Grand Prix GT1 Issue
    By rawr in forum General Tech Discussion
    Last Post: 11-28-2009, 02:15 AM
  4. Ac Blower quits working 2004 Grand Prix GT2
    By downhilljunkie in forum General Tech Discussion
    Last Post: 10-26-2009, 03:25 PM
  5. 2004 GTP traction control issue
    By bentendo92 in forum General Tech Discussion
    Last Post: 02-24-2009, 08:57 PM
