Thread: rpms will not exceed 2000
Results 1 to 5 of 5
  1. #1 rpms will not exceed 2000
    New Hartford, CT
    My '04 Grand Prix will slowly reach higher speeds but the rpms never exceed 2000. Is this a fuel injection problem?
  2. #2 Re: rpms will not exceed 2000
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Check engine light flashing when it happens?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: rpms will not exceed 2000
    Jun 2011
    Oklahoma
    My first guess would be cat-converter then possible fuel pump.
  4. #4 Re: rpms will not exceed 2000
    I live here. TLSheff's Avatar
    Never rule out the simple too... check the plugs.
    I only say this because my Bonnie did the same thing and I had 2 cracked plugs. Don't know if they were cracked by me or before but I had the tech at work look at the car because I was tired of messing with it. I Did a tune up and it still ran like crap then wouldn't rev over 2500 rpms. Babied to work and the tech grabbed 2 plugs and she ran like a champ. He showed them to me and there were hair-line fractures on them both and he said that was the problem, grounding out or something to that effect.
    just a simple check and possibility, take some dirty/dark grease and rub around the ceramic part, if there is a crack the grease will fill into the crack and show up. Free to check, just takes time
  5. #5 Re: rpms will not exceed 2000
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    ^^^^Good input^^^
    Possible bad MAF?
    A friend had a RB25det swapped S14 and with the MAF disconnected (first startup, no cooling stuff or intake piping; open TB) it would ding 2500 and not exceed that. Fuel shutoff and/or spark cut to keep it safe. As I understand it, the ECM didn't know how much air was coming in, so it would just read the MAP sensor and try to keep it a little rich.
    Any codes or idiot lights at all? How long has it been doing this? Does it act like the 4500rpm Park rev-limiter? Is it in gear and park/neutral? The more specific you are, the easier it will be for us to throw out logical ideas. A video would be ideal, though.
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  1. Stuttering at low RPMs
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2011, 08:38 PM
  2. Rpms on the highway?????
    By nickdemio in forum General Tech Discussion
    Last Post: 05-13-2011, 12:27 AM
  3. Fluctuating RPMs 05 GP
    By NegativeOne13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2011, 01:19 PM
  4. RPMs...??
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 11:47 PM
  5. Stalling, low RPMs
    By jdamico84 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-05-2009, 01:01 PM
