Thread: boost problem
Results 1 to 7 of 7
  1. #1 boost problem
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    this may be normal.. but when im driving my boost guage stays at -20 and when i hit the gas it goes up to 4psi max
  2. #2 Re: boost problem
    Wichita
    Could be many things; vacuum leak, clogged cat, bad bbv.
  3. #3 Re: boost problem
    whats your boost read when idling mines -20
  4. #4 Re: boost problem
    -20 is correct, anywhere from -19 to -20 is good.
  5. #5 Re: boost problem
    you mean vacuum measured in in Hg?
  6. #6 Re: boost problem
    and when you rev it how much psi should you be getting out of the car. all i have is an air intake and a new cat but its stock still
  7. #7 Re: boost problem
    you shouldnt get anything when you rev it. the motor needs loan to produce boost.
  1. boost problem
    By Bunique7 in forum General Tech Discussion
    Last Post: 12-26-2010, 10:03 PM
  2. boost problem
    By chunk88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2010, 03:19 PM
  3. boost problem...
    By falcz420 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 07:49 PM
  4. boost lag problem
    By ahemione in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 12:12 PM
  5. problem with ANY boost
    By xwire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2008, 01:43 PM
