Thread: boost problem
Results 1 to 9 of 9
  1. #1 boost problem
    SE Level Member chunk88's Avatar
    Jul 2010
    Richmond, IN
    I have a 2000 gtp and its not building full boost...it was fine untill I hooked up my air/fuel gauge and crossed a wire somewhere now its only running half boost and half vac...I've replaced the pcm and the map sensor neither did any good...car still runs fine otherwise...anyone have any ideas on what I should try?
  2. #2 Re: boost problem
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Check all your vacuum lines again. Did you tap into wires or get the pig tail to connect your A/F gauge?
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: boost problem
    Topeka, KS
    Is it a wide-band or a narrow-band AF gauge. I had a narrow-band and it actually made my car run worse until i unplugged it and got rid of it. Just sayin... Mine was a Auto meter gauge too....
  4. #4 Re: boost problem
    Charles City, IA
    You have a vacuum leak, you probably knock a vacuum hose off somewhere.
    SMGPFC Two Nipple General
  5. #5 Re: boost problem
    You may have popped a fuse in crossing wires. There's many possibles here.
  6. #6 Re: boost problem
    Jul 2010
    Richmond, IN
    i did tap into wires and it is a narrow bang gauge but it was running fine with it hooked up untill i tried to hook up both O2 sensors because i thought it wasn't giving me a correct reading...i've checked my vac lines and every fuse in the car both are good...any other suggestions...could i have set off a check engine code that would cause this?
  7. #7 Re: boost problem
    Oklahoma City
    Quote Originally Posted by chunk88 View Post
    Do you have a SES light if so.. run by your auto parts store and have them scan it real quick. Then throw the code back up on the site.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  8. #8 Re: boost problem
    Jul 2010
    Richmond, IN
    ok...it is on but i know its from not having the MAF sensor hooked up and the rear O2 sensor not being hooked up....both have been unhooked almost as long as i've had the car and never caused any problem other than gas mileage.
  9. #9 Re: boost problem
    Jul 2010
    Richmond, IN
    i had the codes checked and the only one that has never come up before was something like p1336 or something...its a dealer code but it didn't sound like it would have anything to do with the problem
  1. boost problem
    By Bunique7 in forum General Tech Discussion
    Last Post: 12-26-2010, 10:03 PM
  2. boost problem...
    By falcz420 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 07:49 PM
  3. Stuttering problem under heavy boost
    By 02gtp2708 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2009, 12:35 PM
  4. boost lag problem
    By ahemione in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 12:12 PM
  5. problem with ANY boost
    By xwire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2008, 01:43 PM
