So after slowly getting everything together over winter that I need for a solid 3.4 setup, Im going to begin tearing apart the top half and doing gaskets and cleaning everything up nice. I already have ss headers and open cone.
Parts waiting to go on
3.4 zzp mps
Aluminum LIM gasket
GM S/C gasket
Felpro valve cover gaskets w/ gromets
Coolant O-rings
Injector O-rings
Autolite 104 plugs
180 tstat
S/C oil
Parts to pick up
S/C belt
TB gasket
Oil/filter change
Coolant change
DHP canned tune (unless I can find a local custom)
Coolant elbow(s) is there only one on 02 Gtps?
Also going to do a self port job on my blower and have a machine shop port my TB. What should I have it ported to? I was thinking just having the MAF hump removed, would that be best for my setup? And what adhesive should I use for the LIM? this is my first time going this far into the motor so im sure il be coming to you all for other questions and suggestions. I will also try to take as many pics as possible as I go. Is there anything else I should add to the list while everything is apart?
