Thread: Reprogram ECU?
Results 1 to 6 of 6
GPGTdude12 Reprogram ECU? 05-26-2011, 12:23 PM
blueguy Re: Reprogram ECU? 05-26-2011, 12:24 PM
csssaint12 Re: Reprogram ECU? 05-26-2011, 12:24 PM
NegativeOne13 Re: Reprogram ECU? 05-26-2011, 01:07 PM
windowrattler Re: Reprogram ECU? 05-26-2011, 04:31 PM
blueguy Re: Reprogram ECU? 05-27-2011, 04:08 PM
  1. #1 Reprogram ECU?
    Hermitage,TN
    im not exactly sure how to reprogram my ECU chip. i would like to raise my speed limiter up or remove it completely. does anyone know what i can do???
  2. #2 Re: Reprogram ECU?
    Ummm, click the link in my signature then get back to us...and try posting the correct section as well.
    Thanks.
  3. #3 Re: Reprogram ECU?
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    you mean the PCM and there is a write up on how to tune but for now read blue's sig ^
  4. #4 Re: Reprogram ECU?
    Kansas
    Need the likings of HPTuner. Cost you about $500 dollars. It'll cost you that much to go faster. Plus, if you want to be smart about all of this, buy some higher speed rated tires. Thats another 800 at least.
  5. #5 Re: Reprogram ECU?
    I'd guess the cheapest option would be to hit up ZZP and have them flash you a new computer. Can get a few of the little bugs worked out like the speed limiter, skip shifting and a few other things. Think it's $125 for them to flash a PCM.
  6. #6 Re: Reprogram ECU?
    LOL ZZP.
    Buy a DHP from 3800 Performance.
  1. How-to: 5 button DIC upgrade (no reprogram necessary) (04+) [*]
    By TyroElite in forum How To Write-Ups/Tech Tips
    Last Post: 06-05-2012, 11:59 PM
  2. Enough mods for a PCM reprogram?
    By mousemonster1232 in forum General Tech Discussion
    Last Post: 01-27-2011, 11:42 PM
  3. pcm reprogram
    By bballa0740 in forum PCM Tuning
    Last Post: 08-28-2009, 08:14 PM
  4. $$$ How much reprogram the DIC?
    By corvetteii in forum General Tech Discussion
    Last Post: 02-16-2009, 08:56 PM
  5. PCM reprogram
    By sickofsoyo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2009, 01:35 AM
