be aware, the machine shop is going to break through the casting in your throttle body. make sure you add to the outside of the casting before you start porting with some aluminum epoxy.
when i did mine is just let it cut through and later put a piece of tape on the inside of the throttlebody and dumped epoxy on the outside of the throttle body then when it dried removed the tape.
