Thread: This doesn't look right???
Results 1 to 14 of 14
  1. #1 This doesn't look right???
    Donating Users
    Sunbury Ohio
    I'm working my way through an install of SD Headers on my 04 GTP. I got the rear header in and loosely bolted and began to fit the crossover pipe and something didn't seem right. Instead of laying where the OEM crossover did it stuck way out to the side and was pinched between the brake booster and the shift linkage.
    Has anybody else had this problem or seen this? I think if I cut the pipe down it'll be okay but that's ridiculous.....unless I'm really missing something here.
    Check out the pics.
    http://s1176.photobucket.com/albums/...3DIMG_0120.jpg
    http://s1176.photobucket.com/albums/...t=IMG_0123.jpg
  2. #2 Re: This doesn't look right???
    Houston
    Album fail
  3. #3 Re: This doesn't look right???
    yea link does nothing
    SMGPFC Member #10
  4. #4 Re: This doesn't look right???
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Album worked for me. That does look a little off. Don't think your ABS will clear it.
    Lambokit to be built!!!!!
  5. #5 Re: This doesn't look right???
    yea that doesnt look right but i wouldnt cut it
    SMGPFC Member #10
  6. #6 Re: This doesn't look right???
    Donating Users
    Sunbury Ohio
    I test fit the front header and the crossover pipe is off by a country mile. I don't see a way to twist this thing to make sense of it.
  7. #7 Re: This doesn't look right???
    Donating Users
    Sunbury Ohio
    Well after beating out my fire wall for an o2 sensor to fit, snapping my transmission fluid dipstick mount to try to make it fit, hacking up a crossover that didn't fit and rigging it with flex pipe from advanced to get it to my buddies house so he can fab a pipe I've had it with these things and they are going back. I'm sure I'll get a hassle because the crossover is jacked up. I've had to mug my car with a hammer and a grinder all day to get these things to fit and it wasn't even close.
    Are there headers that drop right in with absolutely no problem? I can't take another two days of laying on my garage floor trying to shove a circle through a square. A car shouldn't have to be molded around headers.
    Here's another pic of how the crossover lined up with the front header.
    IMG_0127.jpg picture by donkason - Photobucket
  8. #8 Re: This doesn't look right???
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    yes there headers are bolt right up fit besides the o2 sensor and possibly the tranny dipstick. Mine fit just right but the flex blew out after 3 weeks i had them on. To me it looks like your crossover pipe was not made properly and it is bent completly wrong. Id make them send u some new ones as long as u did not completly destroy them...
  9. #9 Re: This doesn't look right???
    Pennsylvania
    ...rotate the crossover?
  10. #10 Re: This doesn't look right???
    Tough to tell from the angle of the pics. But here's what I would have tried.
    First.. never take out the trans dipstick. It's not in the way. Bolt the rear up tight. Then put the crossover in. Looking at it from teh front, it sits just left of the dipstick and should also be left of the MC/booster. With your pic angle its tough to tell if you couldn't have rotated (or pulled a reinserted) the crossover to be closer to the motor.
    Seems odd that one would be so far off, out of the many that have been done here.
    A great drop in header. SLP. I love SLP's for their super easy, no hassle installs.
  11. #11 Re: This doesn't look right???
    and youre sure the crossover isnt in backwards? it only goes in one way..
  12. #12 Re: This doesn't look right???
    Donating Users
    Sunbury Ohio
    I tried twisting it every which way and to no avail. As for it being backwards I don't think so. The end of the crossover that hooked into the front header was flared and the end that hooked into the rear header was not flared. This matched how the headers were flared for the slip joints. Plus the end piece that hooked into the rear header had an S like bend in it which fit the tight space. Turned around they were all out of whack.
    Everything just needed moved over about 5 inches and the fit would be fine.
    I got PO'd and hacked the pipe trying to fit it so I probably screwed myself out of any refund or a new one for free:-(
    Ima try one more shot and get a new crossover from SD since everything else is installed already. If that doesn't work I'll go with the SLP suggestion.
  13. #13 Re: This doesn't look right???
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    From your pic it looks like the crossover is about two inches too far to the driver side. I recently installed SD headers and mine was that far out.
    Rotate the crossover to get the best combination of angle and closeness. Then, use a wood 2x4 piece between the body to force the front of the crossover to match the front header. Its a matter of shimming garbage between pieces of wood to get it there.
    Looking at the header/crossover junction from the driver side will show that they meet at an ugly ass angle. Push them together and tighten to the head while having as many studs in cyl head as you can. Beat the crossover with more wood occasionally to better slide them together.
    BEFORE you begin this, make sure you can slide the front header into the crossover without effort. If it doesn't, take the pipe to have it expanded. The muffler shop will tell you they split if they are expanded, but I did it because there was no option. Stainless steel actually is very ductile, but then again SD's are more like "mystery steel". The pipes didn't split. Oh and the rear header should be tightened down.
    These are ugly ass headers so you have to beat them at their game.
  14. #14 Re: This doesn't look right???
    Donating Users
    Sunbury Ohio
    That was pretty funny and it was spot on. Too late though since I already hacked it up. I finally called the seller and he offered no real solution for me. He said they don't sell parts of the kit and since I cut it I can't return it. He said he'd talk to his manager about a partial refund but we'll see. Kinda crappy they have no real product support.
    Its time to put it all back together and trailer it to my buddies to custom fit a pipe. He's a wizard with that stuff. I'll have him bump the diamater of the crossover too.
    I've got a 3.4 pulley and a pcm is about to get purchased too so the pain will go away when I lay on the throttle.
    Quote Originally Posted by mechguy View Post
  1. FAQ doesn't work
    By Jakescoots in forum Forum Bugs/Suggestions
    Last Post: 04-23-2011, 10:41 AM
  2. Who Doesn't Own A W-Body?
    By TCO in forum Off Topic Discussion
    Last Post: 03-13-2011, 03:22 AM
  3. Boost doesn't seem right
    By speedy2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2011, 02:46 PM
  4. A/C Works, then Doesn't...?
    By Burls117 in forum General Tech Discussion
    Last Post: 07-03-2010, 06:35 PM
  5. 98 Gtp doesn't turnover
    By avalon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 07:34 PM
