Thread: This doesn't look right???
Results 1 to 14 of 14
  1. #1 Re: This doesn't look right???
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    From your pic it looks like the crossover is about two inches too far to the driver side. I recently installed SD headers and mine was that far out.
    Rotate the crossover to get the best combination of angle and closeness. Then, use a wood 2x4 piece between the body to force the front of the crossover to match the front header. Its a matter of shimming garbage between pieces of wood to get it there.
    Looking at the header/crossover junction from the driver side will show that they meet at an ugly ass angle. Push them together and tighten to the head while having as many studs in cyl head as you can. Beat the crossover with more wood occasionally to better slide them together.
    BEFORE you begin this, make sure you can slide the front header into the crossover without effort. If it doesn't, take the pipe to have it expanded. The muffler shop will tell you they split if they are expanded, but I did it because there was no option. Stainless steel actually is very ductile, but then again SD's are more like "mystery steel". The pipes didn't split. Oh and the rear header should be tightened down.
    These are ugly ass headers so you have to beat them at their game.
  2. #2 Re: This doesn't look right???
    Donating Users
    Sunbury Ohio
    That was pretty funny and it was spot on. Too late though since I already hacked it up. I finally called the seller and he offered no real solution for me. He said they don't sell parts of the kit and since I cut it I can't return it. He said he'd talk to his manager about a partial refund but we'll see. Kinda crappy they have no real product support.
    Its time to put it all back together and trailer it to my buddies to custom fit a pipe. He's a wizard with that stuff. I'll have him bump the diamater of the crossover too.
    I've got a 3.4 pulley and a pcm is about to get purchased too so the pain will go away when I lay on the throttle.
    Quote Originally Posted by mechguy View Post
  1. FAQ doesn't work
    By Jakescoots in forum Forum Bugs/Suggestions
    Last Post: 04-23-2011, 10:41 AM
  2. Who Doesn't Own A W-Body?
    By TCO in forum Off Topic Discussion
    Last Post: 03-13-2011, 03:22 AM
  3. Boost doesn't seem right
    By speedy2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2011, 02:46 PM
  4. A/C Works, then Doesn't...?
    By Burls117 in forum General Tech Discussion
    Last Post: 07-03-2010, 06:35 PM
  5. 98 Gtp doesn't turnover
    By avalon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 07:34 PM
