Thread: Colder plugs early
Results 1 to 7 of 7
  1. #1 Colder plugs early
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    i get my smaller pulley installed on the 28th is it ok to put in colder plugs now? What are the pros and cons?
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  2. #2 Re: Colder plugs early
    I live here. TLSheff's Avatar
    I would wait til you get the smaller pulley and put the plugs in at the same time you install the pulley and then tune immediately after so you don't blow something up
  3. #3 Re: Colder plugs early
    New Carrollton,MD
    I already have a Reptile tuned PCM PLOG Downpipe and intake
  4. #4 Re: Colder plugs early
    With just those 3 your not in need of colder range plugs right now so it would hurt your daily driving more than it would help
    The colder plugs is only needed to help offset the extra heat of the blower when you put a smaller pulley on. The smaller pulley moves the rotors faster, which results in more heat, so colder range plugs helps offset that...
    I believe this is right? I don't want to misinform...
  5. #5 Re: Colder plugs early
    changing the plugs takes 15 minutes, dont waste your time and gas mileage now.
  6. #6 Re: Colder plugs early
    colder plugs burn colder. the hotter the spark, the better the gas burns in the cylinder. you always want to run the hottest plugs you can. however, when you start running more boost you can't run the hotter plugs. predetonation (knock, pinging) is more likely to happen with hotter plugs the more boost you run.
  7. #7 Re: Colder plugs early
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    to cold a plug will foul Quickly. Esp cooper
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. Became impatient.... had to try them out early
    By dengnath in forum Off Topic Discussion
    Last Post: 03-02-2011, 09:34 PM
  2. Got an early Christmas present!
    By 04BlackComp_G in forum Off Topic Discussion
    Last Post: 12-27-2010, 12:34 AM
  3. Early 90's GP wheels?
    By DanGTP in forum Tires & Wheels
    Last Post: 10-04-2009, 09:49 PM
  4. opinion on colder plugs
    By tjvdubsport in forum General Tech Discussion
    Last Post: 06-04-2009, 12:48 PM
  5. Colder spark plugs
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2008, 09:50 AM
