Thread: Colder spark plugs
Results 1 to 20 of 26
  1. #1 Colder spark plugs
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    i was wondering what kind and type of colder spark plugs are u guys running in yalls GP's. Also where did yall get 'em from?
    how are the autolite plus?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #2 Re: Colder spark plugs
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by offroadfury6 View Post
    Unless you are modded to the level of needing colder plugs, don't was the time or money.
    I'm running Champion RS12YC plugs with my mods.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Colder spark plugs
    Aug 2008
    Fayetteville, NC
    well i am stock but im at 60k miles, never changed 'em. couldnt hurt to get something nice...my baby deserves it !
  4. #4 Re: Colder spark plugs
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I would use AC delcos. Thats what I use.
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  5. #5 Re: Colder spark plugs
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    From what i understand hotter plugs are better and you should not drop temperatures unless necessary. If you are getting Knock from your car then you may want to move down to colder plugs. It appears most people would recommend Autolite 104's. If not just replace the stock plugs with AC Delcos. With your mods you should be getting little to no Kr so a temperature drop should not be necessary.
    2006 Grand Prix GXP
  6. #6 Re: Colder spark plugs
    SE Level Member crimpton's Avatar
    Aug 2008
    Portland, Oregon
    I run 103's, but change them annually. Copper plugs don't last as long as platinums so you will need to change them regularly. You can get cooler platinum plugs but I don't have any niumbers.
  7. #7 Re: Colder spark plugs
    Banned
    Wichita Falls, Texas
    You'd be alright going ahead and putting Autolite 104's in if you plan on doing some mods later on. If your staying stock then there really isn't any point.
  8. #8 Re: Colder spark plugs
    Aug 2008
    Fayetteville, NC
    =P im saving my cash, starting this paycheck, i want headers and the downpipe. then overkills pcm
  9. #9 Re: Colder spark plugs
    May 2008
    McHenry IL
    sounds like a good plan man!
  10. #10 Re: Colder spark plugs
    Aug 2008
    Fayetteville, NC
    yeah it could defently work.
  11. #11 Re: Colder spark plugs
    Aug 2008
    Fayetteville, NC
    i purchased 104s today and look like a tough job to do so imma wait until tomrrow...
    BTW im using my intake, fixing to buy a PCM, would this be enough to do a 3.4 pully?
  12. #12 Re: Colder spark plugs
    Jul 2008
    New York
    I doubt anyone here would suggest dropping to a 3.4" pulley with only a pcm, intake and plugs.
    Most important you should have access to a scanner to scan for Kr. Every car is different but i feel safe saying you will most defiantly get KR. You should have some exhaust work done. U-bend delete, dp and [to be safe] a plog would be ok for a 3.5 but you would most likely need headers for a 3.4. Also a colder t-stat would be a good idea.
    Is your intake cold air? A cold air or fender wall intake would be best to battle Kr.
    2006 Grand Prix GXP
  13. #13 Re: Colder spark plugs
    Aug 2008
    Fayetteville, NC
    yeah looking into, 3.4, t-stat, colder plugs (have), intake (have that too), DP, and ubend delete...this should hold the 3.4
  14. #14 Re: Colder spark plugs
    Donating Users blowfishRus6's Avatar
    g.a.
    throw a p-log in there just to be safe
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  15. #15 Re: Colder spark plugs
    g.a.
    a 3.4 effects our gen V blowers more than the gen III. they say the 3.5 for us is like a 3.4 on the gen III. and if you ever seen the front manifold pulled off it really is constricting, and with the extra 20hp from the gen V i would be a safe bet to get the p-log.
    its slow.
  16. #16 Re: Colder spark plugs
    Aug 2008
    Fayetteville, NC
    of course overkills pcm
  17. #17 Re: Colder spark plugs
    Aug 2008
    Fayetteville, NC
    who sells the p-log zzp?
  18. #18 Re: Colder spark plugs
    Aug 2008
    Fayetteville, NC
    DNA i custom made my fenderwell intake today
  19. #19 Re: Colder spark plugs
    g.a.
    yea 120$
    its slow.
  20. #20 Re: Colder spark plugs
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    zzp sells the front powerlog. i would splurge for the ceramic coated too.
  1. Side Gap Spark Plugs [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2010, 12:26 PM
  2. Changing the Spark plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:24 AM
  3. Spark Plugs
    Last Post: 07-27-2008, 10:45 PM
  4. Bosch Spark Plugs?
    By DanGTP in forum General Tech Discussion
    Last Post: 04-23-2008, 02:24 PM
  5. A look at different types of spark plugs
    By SyntheticShield in forum General Tech Discussion
    Last Post: 04-10-2008, 11:24 AM
