Thread: s/c case bearings
Results 1 to 5 of 5
  1. #1 s/c case bearings
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    ok so i know that some people here have replaced them, and that is what i am trying to do, but even tho i have tapped the holes for 5/16 and used a 5/16 bolt drilled threw with a grease sert on top, the things still will not come out, any idea's why? is there any other alternative to getting these out?
  2. #2 Re: s/c case bearings
    they should come out with the grease gun, but might take a little bit of effort.
  3. #3 Re: s/c case bearings
    St. Louis
    That is what I thought also but I pumped on them for like 10 minutes....and nothing
  4. #4 Re: s/c case bearings
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Humm. Try a different grease gun. It's going to be messy, but they will come out. Is grease coming out from anywhere now? If so something is not tight. The one side is easier if you use an extension. The Bolt you are using with the grease cert on top isn't leaking is it? The grease fitting to use directly into the housing is a 1/8th pipe tap. This is what I used.
    Lambokit to be built!!!!!
  5. #5 Re: s/c case bearings
    St. Louis
    Got them out today the problem was the grease gun...bought a different one and BAM!
  1. hub/bearings/breaks?? Help Please
    By jayson14 in forum General Tech Discussion
    Last Post: 04-10-2011, 05:52 PM
  2. Wheel Bearings?
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2010, 08:05 PM
  3. Bearings
    By LukesGTP in forum Tires & Wheels
    Last Post: 04-19-2010, 02:57 AM
  4. Wo has changed the case bearings out of a GEN V????
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 07:01 PM
  5. Replacing bearings for SC case
    Last Post: 06-17-2009, 02:31 PM
