Thread: Loose connection? Being slowly driven mad!!
Results 1 to 8 of 8
  1. #1 Loose connection? Being slowly driven mad!!
    Mesa, Arizona
    For right at 3 weeks now, the car has been shutting down in mid-flight so to speak.
    I will be driving down the road and suddenly the car simply shuts off. Electrical power is still on, raido, lights, etc. I pull over and stop and it almost always starts right up again. I continue down the road and it does it again. Sometimes it will go 20 miles with no problem and then other times it will shut down 5 times in 5 miles.
    Now, this situation is most often accompanied by the "Service Engine Soon" light. That light comes on and I know that it's trouble. Now, I can sometimes prevent it from shutting down by reving the engine some. I slip it into neutral and give it some gas. This seems to help prevent it. Sometimes though it just shuts down to quickly for me to catch it and sometimes that doesn't work anyway.
    It SEEMS to be associated with the engine getting hotter, on occasion the car overheats (another problem to fix) and when that happens it SEEMS to occur much more frequently.
    Good mechanic I know with a lot of experience gets the "feeling" that there is some kind of loose connection.
    I am ready for the insane asylum with this thing. It seems that if it was a sensor, the sensor would have completely failed by now, 3 weeks after the problem started. The codes have been read and there is no current code.
    Please offer your best guess or theory on this maddening motor vehicle!!!
    Thanks!!!
  2. #2 Re: Loose connection? Being slowly driven mad!!
    Pennsylvania
    How many miles?
    Is the light blinking?
    Did you bother to get it scanned for free at any auto parts store? Codes?
    I don't like your mechanic friend; Oprah has the feelings, not mechanics. Nothing's getting disconnected.
    Clogged cat, bad thermostat
  3. #3 Re: Loose connection? Being slowly driven mad!!
    Mesa, Arizona
    Quote Originally Posted by SlowNA06 View Post
    How many miles?
    255,000 miles
    Service engine soon light comes on periodically, doesn't "blink". It comes on for awhile, which usually means the car will shut down or it stays on a while, minute maybe two, and then just goes off
    Been scanned. Shows history of codes; ERG, MAF but no current codes and a shop had it for 3 days and it would not do what it does for me while there and they gave up!
    The mechanic I referenced is good. He was just referring to the symptoms as I desricbed them and he said from what he knows and has experienced over the last 45 years doing mechanic work it sounds like it could be a loose/bad connection.
    Anyone have any other theories?
  4. #4 Re: Loose connection? Being slowly driven mad!!
    Mesa, Arizona
    It SEEMS to get worse as the car heats up but not always!!!
  5. #5 Re: Loose connection? Being slowly driven mad!!
    Chilliwack BC
    weird no codes. hmm clogged fuel filter ? fuel pump perhaps? it needs to be duplicated at a shop pretty much at this point. thats my best guess
  6. #6 Re: Loose connection? Being slowly driven mad!!
    Mesa, Arizona
    Quote Originally Posted by Couch View Post
    Heard that fuel filter clogging is rare but maybe....
    Replaced the fuel pump 2 years ago so that should be okay.
    Yeah, it is weird alright!
  7. #7 Re: Loose connection? Being slowly driven mad!!
    Mesa, Arizona
    MAP sensor was going bad, that was it. All fixed. :-)
  8. #8 Re: Loose connection? Being slowly driven mad!!
    Mesa, Arizona
    How many miles?
  1. internet connection
    By Wadeb79 in forum Off Topic Discussion
    Last Post: 05-07-2012, 05:06 AM
  2. Window goes up slowly? Help
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-10-2010, 04:54 PM
  3. ECM To OBDII Connection
    By lstexan in forum General Tech Discussion
    Last Post: 02-07-2010, 03:05 PM
  4. It's slowly coming together... (lots of pics 56K)
    By Smokin2000gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2008, 04:42 PM
  5. Possible to change drive/driven sprockets in-car?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2008, 03:18 PM
