Thread: Cooling fans and A/C issue *need help
Results 1 to 6 of 6
WRIGHTDA Cooling fans and A/C issue... 05-04-2011, 07:25 PM
dpzelenak Re: Cooling fans and A/C... 05-04-2011, 07:36 PM
BillBoost37 Re: Cooling fans and A/C... 05-05-2011, 09:39 AM
vsixer Re: Cooling fans and A/C... 06-07-2012, 06:03 PM
pabstman Re: Cooling fans and A/C... 10-06-2012, 07:41 AM
vsixer Re: Cooling fans and A/C... 10-06-2012, 11:45 PM
  1. #1 Re: Cooling fans and A/C issue *need help
    Jun 2012
    Somewhere
    Quote Originally Posted by pabstman View Post
    Hi guys. I just bought a 89 GP 3.1 same issue both fans won't come on. Any answers?
    Well I hooked my buddies snap on scanner to the my car and turned the fans on thru it proving the fans the relays and fuses worked. I also check the temp sensor and it was telling the computer to turn the fans on. So the GM trouble shoot manual said it was the ECM. Replaced the ECM and it worked fine. Must have been a bad solid state relay in the ECM board.
    Having the correct diagnoistic equipment can sure cut down on the repair time. Other wise it would have took a while to figure it out.
    AC issue was a bad clutch on the compressor. I cut a plug off a car in the junk yard and wire up and jumped the AC direct to the battery and it would not engage. replaced the compressor and fixed the issue.
  1. Cooling Fans not kicking on.
    By kaylin4u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2013, 12:07 PM
  2. Cooling Fans Not Working
    By 1FASTGTO in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-23-2011, 01:17 PM
  3. Replaced ECT sensor, cooling fans don't come on now
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-27-2010, 06:09 PM
  4. Cooling fans only work with ac
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2009, 08:54 AM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
