Thread: Cooling fans and A/C issue *need help
Results 1 to 6 of 6
Threaded View
WRIGHTDA Cooling fans and A/C issue... 05-04-2011, 07:25 PM
dpzelenak Re: Cooling fans and A/C... 05-04-2011, 07:36 PM
BillBoost37 Re: Cooling fans and A/C... 05-05-2011, 09:39 AM
vsixer Re: Cooling fans and A/C... 06-07-2012, 06:03 PM
pabstman Re: Cooling fans and A/C... 10-06-2012, 07:41 AM
vsixer Re: Cooling fans and A/C... 10-06-2012, 11:45 PM
  1. #1 Cooling fans and A/C issue *need help
    May 2011
    jacksoncille nc
    1998 Pontiac Grand Prix SE 3100
    Problem..A/C and cooling fans won't kick on.
    Corrective measures...
    Checked fuses..all good
    Changed all 3 cooling fan relays..no help.
    Direct connect to battery to check fans..they worked.
    Recharged the A/C..needed like 10 more PSI..no help.
    Changed coolant temp sensor..no help.
    Changed ambient air sensor..no help.
    Changed Air charge sensor..no help.(runs better after this though)
    Previous repairs..
    Water pump and belt replaced.
    Heater motor blower replaced.
    Blower motor resistor replaced. (vents now blow heated air and air from outside)
    Fans won't kick on nor will A/C at this point. I have been reading for hours. I read somewhere there is an inside air temp sensor, but I can't find it. I noticed a female connector by the battery with the same color wires as the ambient air temp sensor not plugged into anything. Looked for about an hour for the male connector but I can't find it.
    Any ideas or can someone send me a pic of where the connector next to the battery with a yellow and green wires go to?
  1. Cooling Fans not kicking on.
    By kaylin4u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2013, 12:07 PM
  2. Cooling Fans Not Working
    By 1FASTGTO in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-23-2011, 01:17 PM
  3. Replaced ECT sensor, cooling fans don't come on now
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-27-2010, 06:09 PM
  4. Cooling fans only work with ac
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2009, 08:54 AM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
