Thread: Cold air induction systems - differences
Results 1 to 8 of 8
GPrixGT00 Cold air induction systems -... 05-06-2011, 11:05 AM
Dallasneon Re: Cold air induction... 05-06-2011, 11:19 AM
Lenny Re: Cold air induction... 05-06-2011, 11:26 AM
SlowNA06 Re: Cold air induction... 05-06-2011, 11:32 AM
matt5112 Re: Cold air induction... 05-06-2011, 11:43 AM
kissmyss Re: Cold air induction... 05-06-2011, 06:11 PM
matt5112 Re: Cold air induction... 05-06-2011, 06:40 PM
CBWhite Re: Cold air induction... 05-07-2011, 09:23 AM
  1. #1 Cold air induction systems - differences
    SE Level Member GPrixGT00's Avatar
    May 2011
    Daytona Beach
    CAN ANYONE TELL ME THE MAIN DIFFERENCES BETWEEN THE TWO CAI'S FROM ZZP:
    ZZP 3800 cold air intake - $209.99
    Model
    Series II Series III * Out of Stock *
    Writeup coming soon.
    Includes:
    Air box with lid
    Intake duct rotates for different throttlebody setups
    PCM tray
    4" heat shielded tube
    (3) hose clamps
    K&N 4" inlet 9" cone filter (optional)
    AND THE:
    Wizaired Cold Air Induction System - $199.99
    Model
    Standard Series 3 (+ $20.00) Intercooled (+ $20.00) LS1, or N* throttlebody (+ $45.00) 3400 series (+ $20.00) Option 1
    none selected Add 4 inch K&N filter (+ $44.00)
    I'M LOOKING TO INSTALL ONE OF THE TWO AND I'M WANTING TO KNOW THE DIFFERENCES AND WHY ONE IS BETTER THAN THE OTHER IF SO. OBVIOUSLY THE WIZAIRD COMES W/O AIR FILTER AND LOOKS A LITLE DIFFERENT. BUT ARE THERE BIG TECHNICALITIES BTWEEN THE DIFFERENCES?
    PLEASE DON'T MIND THE CAPS, I KEEP EM THAT WAY BECAUSE OF HOW I TYPE THINGS AT WORK.
  2. #2 Re: Cold air induction systems - differences
    Keller,TX
    There is no difference. To buy one of these is strictly for cosmetic purposes, theres no gain over making one for $50 out of Home Depot parts.
    Edit: The ZZP one looks to fit better than the Wizaired one I had.
  3. #3 Re: Cold air induction systems - differences
    GT Level Member Lenny's Avatar
    Jul 2010
    41 R QR 51938 02935
    search the forum for the write up on how to build your own... PVC elbow, a couple clamps, and a good filter. its cheap, and it flows.
    2007 Grand Prix GXP
  4. #4 Re: Cold air induction systems - differences
    Pennsylvania
    Looks like the ZZP comes with a filter and the Wizaired is $44 extra for the filter.
    Performance difference is nil.
  5. #5 Re: Cold air induction systems - differences
    I mind the caps a lot....
    Its one keystroke to turn the caps lock off.
    Replace your tubing, gut the stock box, throw a huge cone in it.
    cheaper and better.
  6. #6 Re: Cold air induction systems - differences
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    And this one;
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  7. #7 Re: Cold air induction systems - differences
    Thats dumb.
    They kept the one part of the intake you're supposed to throw out.
    Also why do they increase the costs by having a window so you can see?
    Thats also another side that doesnt have the heat rejecting material on...
    They really make these to be pretty....
  8. #8 Re: Cold air induction systems - differences
    Nov 2010
    Baltimore
    I have a wiz aire myself. Nothing wrong with making your own, but i don't understand why you guys use pvc pipe. I don't know what else you can use, but that sh#% gets hot! Next time after a good drive pop the hood and put your hand on it.
  1. What up = cowl induction hood
    By gamboa5150 in forum Introductions/Noob Questions
    Last Post: 08-28-2010, 12:01 AM
  2. Custom Cold Air Induction [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 07-04-2009, 05:05 PM
  3. Cold Air Intake mitigated by forced induction?
    By Chernobyl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2009, 02:28 PM
  4. Quick question on Air Induction CAI
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2008, 01:26 AM
