I have read countless articles on SC pulley replacement and am ready to do my own. I run my '05 GTP exclusively at high altitude. Where I live (Denver) the normal air pressure is 12.1 to 12.2 psi. For those of you at sea level, you're at 14.7 and the other 90% or so of you are at about 1000 ft above sea level, which gives 14.2 psi atmospheric pressure. I'm planning some upgrades, but would like some advice. Right now I'm totally stock. I was thinking about running a 9-inch open cone, Autolite 104's and a 3.4 inch pulley with a tuned Overkill PCM. Here's the rub: I believe the normal amout of boost from the GenV in the 05+ (better airflow than 04) is about 8psi. That would bring the manifold pressure at sea level to 22.7 psi. Changing to a 3.4" pulley would add about 2.5psi boost, bringing the pressure to about 30psi, roughly. Since I lose 2.5 psi from the get go due to altitude, would a 3.4 pulley bring me back to sea level conditions with a stock pulley? If that's the case, should I tell Overkill that I'm running a stock pulley to get a proper tune since the air pressure to the manifold would be about the same as a stock pulley at sea level? Should I choose an even smaller pulley size? For reference, I rented an N/A GP when I was in Boston and it felt like it had more "juevos" than my GTP Comp G at home.
Thanks in advance for any advice.
