im halfway done with porting my gen 3 and upon pulling it apart i noticed the bore that the rotors run in has a few grooves worn in i was just curious if this was normal or some jackass before me decided to run a ****ty filter or none at all
Are they serious groves? Or just visual?
As in, can you feel them?
Because it sounds like a lack of air filter.
i'd look over the rotors to look for signs of flaking of the coating.
Other than that I really wouldnt worry about it as long as the groves don't protrude the rest of the case.
I.e. can come into contact with the rotors.
most the scratches arent very wide but deep enough to be felt a bit, ill have to look again in the morning at my rotors but iirc it looked as tho they had carbon build up im not sure what the coating looks like. and if thats it im sure its starting to go cus on the needle bearing ends i remeber them being relatively clean.
if the coating is gone will it hurt performance or will it still be fine, if i need to replace them where can you get new rotors
if you've got carbon build up on the rotors then you're good.
Generally the carbon sticks to the teflon coating.
Leave the carbon on. both the rotors and the casing. It's helping to seal them to the casing. As for the grooves. Pics please. Usually a few grooves are normal.
