Thread: Supercharger case question
Results 1 to 10 of 10
  1. #1 Supercharger case question
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    im halfway done with porting my gen 3 and upon pulling it apart i noticed the bore that the rotors run in has a few grooves worn in i was just curious if this was normal or some jackass before me decided to run a ****ty filter or none at all
  2. #2 Re: Supercharger case question
    Are they serious groves? Or just visual?
    As in, can you feel them?
    Because it sounds like a lack of air filter.
  3. #3 Re: Supercharger case question
    Jun 2010
    Beloit, WI
    there are a few but yea they can be felt
  4. #4 Re: Supercharger case question
    i'd look over the rotors to look for signs of flaking of the coating.
    Other than that I really wouldnt worry about it as long as the groves don't protrude the rest of the case.
    I.e. can come into contact with the rotors.
  5. #5 Re: Supercharger case question
    Jun 2010
    Beloit, WI
    most the scratches arent very wide but deep enough to be felt a bit, ill have to look again in the morning at my rotors but iirc it looked as tho they had carbon build up im not sure what the coating looks like. and if thats it im sure its starting to go cus on the needle bearing ends i remeber them being relatively clean.
    if the coating is gone will it hurt performance or will it still be fine, if i need to replace them where can you get new rotors
  6. #6 Re: Supercharger case question
    Jun 2010
    Beloit, WI
    i forgot, about the buildup of what looks like carbon on the rotors will leaving this be fine because i fear that if i clean it all off ill lose some boost
  7. #7 Re: Supercharger case question
    if you've got carbon build up on the rotors then you're good.
    Generally the carbon sticks to the teflon coating.
  8. #8 Re: Supercharger case question
    Jun 2010
    Beloit, WI
    will it hurt to clean the carbon off or should i leave it
  9. #9 Re: Supercharger case question
    Leave the carbon on. both the rotors and the casing. It's helping to seal them to the casing. As for the grooves. Pics please. Usually a few grooves are normal.
  10. #10 Re: Supercharger case question
    do not touch the insides of the case or the rotors.
    also, my case was grooved to hell and still made 14 pounds of boost. i'd leave it alone.
  1. Supercharger snout and case cleaning
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2011, 05:05 PM
  2. question supercharger
    By timmysgtp in forum General Tech Discussion
    Last Post: 08-16-2010, 06:35 PM
  3. Supercharger Question
    By supercharged06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 11:48 AM
  4. new supercharger question
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 09:49 AM
  5. Replies: 6
    Last Post: 04-19-2009, 12:49 PM
