Thread: cant get radiator fans to work
Results 1 to 3 of 3
  1. #1 cant get radiator fans to work
    Apr 2011
    hemet, ca
    I've got a 97 grand prix gt it was running really hot and I found that the cooling fans weren't turning on. When I unplug the coolant temp sensor both fans turn on so I figured the sensor was bad and I changed it. The fans are still not turning on unless the wire is disconnected from the sensor. Did I buy a bad sensor or is something else wrong? There is a inline connector further down the wire going from the coolant temp sensor to the pcm which I unconnected and connected but still can't get my fans to turn on. I'm stumped please help.
  2. #2 Re: cant get radiator fans to work
    May 2011
    jacksoncille nc
    Having somewhat the same issue, I will try to unplug my sensor and see what happens. Does your A/C work?
  3. #3 Re: cant get radiator fans to work
    Let's test that the pcm wants to turn the fans on. turn your ac on full max and coldest setting. Do your fans come on? They should.
    If you pass that test.. let's tell you that the fans are programmed to come on at 216F low speed and high speed at 228F.
    Yeah..pretty high huh?
  1. coolant fans only work when A/C is on
    By bigwillie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-26-2011, 07:14 PM
  2. Should my radiator fans be on all the time?
    By yekimmrt in forum General Tech Discussion
    Last Post: 12-20-2010, 07:26 AM
  3. 92 Grand Prix radiator fans
    By 92GrandPrixLE in forum General Tech Discussion
    Last Post: 06-05-2010, 05:38 PM
  4. Cooling fans only work with ac
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2009, 08:54 AM
