Thread: 3.8 rear spark plug issue
Results 21 to 40 of 71
  1. #21 Re: 3.8 rear spark plug issue
    Quote Originally Posted by L36pro View Post
    the header bolts hold them in.
    How come you have so many 3800 cars and yet you don't know that the engine pull brackets are NOT attached to the manifolds?
    Seriously.
    The misinformation is really getting my last nerve.
    The front one is bolted to the cylinder head along with the rear one. The Exhaust manifold studs are tiny...and they sure don't have enough strength to be chained up and use to pull out a 500lb. cast iron pushrod motor.
  2. #22 Re: 3.8 rear spark plug issue
    SE Level Member TheManiac's Avatar
    Nov 2010
    Mentor, OH
    I just removed the front one on my '04 Monte with a L36 while installing a ZZP Plog. The front lift bracket has one bolt directly to the head. The other side of it is attached to the exhaust manifold STUD and held to that stud with a nut. So, a tiny exhaust stud DOES share some of the load. I had no reason to mess around in the back, but I would imagine the rear lift bracket is the same way.
  3. #23 Re: 3.8 rear spark plug issue
    OP.. unbolt the dog bones at the motor side. The one on the coil pack has a second bolt hole back a little. Pull the motor forward and put the bolt through the dogbone and that hole. This is there to hold the motor forward. Leave the straps and other things that might break/slip etc and hurt you to the others. Be safe.
    Engine lift brackets. Maybe you guys haven't spent enough time under the hoods? The exhaust manifold goes on the head. Then the engine lift bracket covers the end stud of the exhaust manifold and it held to the head/manifold stud with a nut on the stud and a short bolt to the head. Both 13mm's. Any other questions?
    Nick..sorry to say it man. You're the misinformation on this one. The exhaust manifold studs are not tiny. you thinking of the Racebalt?
  4. #24 Re: 3.8 rear spark plug issue
    Nope...because I'd never rely on an exhaust stud to lift a motor...hence why I don't even use the factory hoist brackets.
    I've got better spots like the right dogbone bracket and the long alternator bolt that goes back in around the chain.
  5. #25 Re: 3.8 rear spark plug issue
    The right being the cast iron coil pack bracket. Yeah, that's good. But the aluminum driverside (aka left) one is weak and shouldn't be relied on...it breaks easy bud. Although I've never broken one.
  6. #26 Re: 3.8 rear spark plug issue
    Banned
    Apr 2011
    wv
    ok, then how do you explain the fact that i had to pull the bracket off to get my front manifold off. ONE bolt is bolted to the cylinder head, while the other is bolted to the manifold. fail
  7. #27 Re: 3.8 rear spark plug issue
    So L36 Pro...your 1 for 4.
    25% success rate isn't too good.
  8. #28 Re: 3.8 rear spark plug issue
    Banned
    Apr 2011
    wv
    counting this one, the antiseize, the coolant elbows...... actually im 3 for 4.
  9. #29 Re: 3.8 rear spark plug issue
    SE Level Member jpdubrall84's Avatar
    LeMars, IA
    actaully counting this one, the antiseize, the coolant elbows...... actually im 3 for 4.
    Yea but you're cocky and arrogant....so that's a -50% on your total score.
    My car is not stock....It's an empty canvas for a work of art.
  10. #30 Re: 3.8 rear spark plug issue
    Banned
    Apr 2011
    wv
    not cocky, just defensive. every post i make is keenly observed by bluegtp, then exploited for grammatical, and factual errors.
    and i never said that hoisting the engine up by the exhaust manifold bolts was a good idea, or even safe. if it ever comes to that i will probably hoist it up using the motor mounts and alt bracket like bluegtp suggested, but the brackets will be for added reinforcement.
    oh and the vr1 topic, so 4 for 5. or is it 4 for 4?
  11. #31 Re: 3.8 rear spark plug issue
    The VR1 topic you fail...because you don't even use it and you don't even know the reasons I run it...even though I already did tell you.
    It has higher levels of zinc in it...therefore it is better for the bearings in your motor. Also, like I had previously stated...lots of large lift cam cars run a thicker weight oil because they idle lower and it is harder on the rotating assembly. I've tried to tell you all the faults in your posts so you can learn, but obviously that isn't working.
  12. #32 Re: 3.8 rear spark plug issue
    Banned
    Apr 2011
    wv
    i know why you run it, and i know your oil pump wont forgive you. neither will your cold starts
  13. #33 Re: 3.8 rear spark plug issue
    So technically speaking. The lift bracket is on nut and one bolt. The stud that the nut goes on is threaded into the head
  14. #34 Re: 3.8 rear spark plug issue
    You do know these pumps are crank driven? They never go bad...and if they do I've never seen one go bad.
  15. #35 Re: 3.8 rear spark plug issue
    Banned
    Apr 2011
    wv
    but it goes through the exhaust manifold like the others.
  16. #36 Re: 3.8 rear spark plug issue
    Banned
    Apr 2011
    wv
    well hopefully the zinc will even out the damage from your cold starts.
    but that depends on where you live
  17. #37 Re: 3.8 rear spark plug issue
    GT Level Member starscream5000's Avatar
    Kentucky
    Good God man, just let it go already. Who are you trying to impress?
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  18. #38 Re: 3.8 rear spark plug issue
    Remind me never to travel to West Virginia.
  19. #39 Re: 3.8 rear spark plug issue
    Pennsylvania
  20. #40 Re: 3.8 rear spark plug issue
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I use the brackets on the manifolds/heads to pull motors. There's a reason they come on the motor from the factory people... Unless you have really rusted out studs I would pull there.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  1. Spark plug gap?
    By 91z in forum General Tech Discussion
    Last Post: 04-20-2011, 08:28 PM
  2. Spark plug
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-01-2011, 02:48 AM
  3. Spark Plug Help
    By STP5593 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 10:15 PM
  4. Spark plug issue?
    By TurboKent in forum General Tech Discussion
    Last Post: 04-12-2008, 03:07 PM
