Thread: Starting getting worse
Results 1 to 8 of 8
  1. #1 Starting getting worse
    GT Level Member fri3dchick3n's Avatar
    Alaska
    My car in the summer usually starts great, kachik vroom. But lately the car would bog when I start it then work its way up to 1k rpms. Today I witnessed actually knocking noise when starting, kind of scared me a bit and also today after the car was parked for a few hours. It had to turn over quite a bit to start. Not normal.
    I smell oil once in a while also : /
    I've wanted to change the module that the coil packs sit on for a while now.
    But I would like your input first of course, anyone experience this problem before? Any tips would be awesome.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  2. #2 Re: Starting getting worse
    Banned
    Apr 2011
    wv
    take the module to autozone right off your car while warm, and have them test it. as far as starting issues, are you saying that when its cold its not starting? or that it just isnt starting normally, period.
  3. #3 Re: Starting getting worse
    Alaska
    I'm saying that the car starting is not normal. And it seems to be getting worse slowly. So I can just have oreillys test it for me?
  4. #4 Re: Starting getting worse
    Akron Ohio
    EGR valve? Thats what happend to my Acura TL.
  5. #5 Re: Starting getting worse
    maybe its not getting fuel right away.
  6. #6 Re: Starting getting worse
    Alaska
    I read up on a bad EGR valve. And I think I want to clean mine up. I think I know what/where it is but I am not sure. Anyone have a pic or simple directions to find this buster?
  7. #7 Re: Starting getting worse
    Banned
    Apr 2011
    wv
    autozone can test the starter. pull it off and bring it to them, or take the whole car to them. either way.
  8. #8 Re: Starting getting worse
    Alaska
    I will try to take it to them and have it tested although all of a sudden the car starts great lately. Whatever.
    Here is an example of something wrong with my car:
    7fbac412.mp4 video by fri3dchick3n - Photobucket
    At the 0:10 mark you can here a change in the engine tone and power.
    And under, I'd say a 10% throttle, cruising, the car would work its way down to 1400-1500 rpms and studder. So I think if I change out the module that I was talking about earlier, I think it will fix the problem.
  1. Cleaned the TB, Runs worse?
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2011, 08:26 PM
  2. Car starts and stalls worse with throttle
    By gprixster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2009, 05:44 PM
  3. Can electric superchargers get any worse.....YES THEY CAN
    By 98GT3800 in forum Off Topic Discussion
    Last Post: 06-29-2009, 06:39 PM
  4. Window rattle worse
    By WhiteDevil in forum 04+ Specifics
    Last Post: 04-20-2009, 04:41 PM
  5. Things Just Keep Getting Worse *Electrical Problem*
    By GTPJay305 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-04-2008, 12:17 AM
