Thread: Car acts like it's dead helP please
Results 1 to 13 of 13
  1. #1 Car acts like it's dead helP please
    Yoga city
    Well get off work got to start the gtp and bam no power and my key is stuck so I got it out and jumPed didnt start right up but let it charge?
    Z starts up, so I get home shut it off and it does it again like what the f!
    I pop the hood check terminals and looks good , so I see my lights come back on the inside so I try and start it started up by itself and I checked my battery voltage and it's steady holding 12.8 so does anyone have a clue to what might be going on for me? Thanks in advance for trying
  2. #2 Re: Car acts like it's dead helP please
    have you tried the wiggle test?
    what is the battary voltage after you let it sit for awhile?
    SMGPFC Member #10
  3. #3 Re: Car acts like it's dead helP please
    Yoga city
    Battery is at 12.8v
  4. #4 Re: Car acts like it's dead helP please
    Yoga city
    I'll check now and the"wiggle" test?
  5. #5 Re: Car acts like it's dead helP please
    grab the wiring harness a shake it,
    if you have a shorted wire it could be moving with the car and causing a intermittent problem making the car act as if you had a dead battary
    SMGPFC Member #10
  6. #6 Re: Car acts like it's dead helP please
    so the battarys still at 12v after its been sitting for awhile right?
    that means you dont have somthing staying on a draining the battary as it sits
    SMGPFC Member #10
  7. #7 Re: Car acts like it's dead helP please
    Yoga city
    Nothing draining the battery nothing on it's weird I was in my car to put something away locks work and unlocked but yeah I just started it I'm baffled
  8. #8 Re: Car acts like it's dead helP please
    St. Louis
    So you go to start it and ALL power drops out. Everything dead?
    Remove the battery cables and clean them. Then tighten em back up and see what you get.
  9. #9 Re: Car acts like it's dead helP please
    Mercer, Pa
    middle 12's is normal for a battery with car not running. high 13 or 14 for a running car. Use a multimeter to measure the voltage?
  10. #10 Re: Car acts like it's dead helP please
    Yoga city
    All my voltages are right on
  11. #11 Re: Car acts like it's dead helP please
    Houston
    Are you just testing at the battery? I would check the voltages at the fuse block under the hood and also at the ignition wires under the dash. If the voltage is off there, you will want to redo your battery cables.
  12. #12 Re: Car acts like it's dead helP please
    Yoga city
    Well that's the thing Ive measured battery and cables and it's all within the nor
    Al voltages
  13. #13 Re: Car acts like it's dead helP please
    Check the connections. Don't just feel them or look at them while they are connected. Pull them and look at them.
  1. Is it dead?
    By klj5022 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2011, 10:49 AM
  2. When downshifting on a hill trans doensn't hold car back acts like neutral
    By 1997GSX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-20-2010, 03:04 PM
  3. Car acts like its missing and its not!!!
    By djmack7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2010, 12:07 PM
  4. Car acts as good as the weather does?
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2009, 10:43 AM
  5. Hello I am the Dead-Man
    By iamthedeadman in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:31 PM
