Thread: Common AC Leak Points or Failure Grand Prix
Results 1 to 20 of 22
  1. #1 Common AC Leak Points or Failure Grand Prix
    GT Level Member mainecrab's Avatar
    Feb 2008
    I have a 97 Grand Prix GT. I have an AC leak that I can hear is near the compressor area but cannot pinpoint where. Should I just replace the entire hose ac accumulator and compressor and that should fix it? well I mean as well as the orifice tube and vacuum check pressure and refill?
    Its weird ebcause when I put in the freon it will hold about a day but last night I could hear it coming out but it was cold so it seemed maybe a bad O ring or something? Would a bad compressor still get cold temps? it wasnt too loud either.
  2. #2 Re: Common AC Leak Points or Failure Grand Prix
    you can use freon with leak detector die in it so where it turns red, you found your leak, then repair where the leak is and recharge it.
  3. #3 Re: Common AC Leak Points or Failure Grand Prix
    Feb 2008
    Yeah I used UV dye but I didnt see it anywhere that I could fit the UV lamp. I guess ill have to try it again.
  4. #4 Re: Common AC Leak Points or Failure Grand Prix
    Never Never Land
    same thing happened to me...put die in let the a/c run for a while to circulate the die..never found a leak..but i always lose the freon...however once it gets down to like 15 psi it holds and doesnt go any lower..odd to me lol..im assuming its an o-ring that cant handle the high pressure but can handle the lower pressure.
  5. #5 Re: Common AC Leak Points or Failure Grand Prix
    Topeka, KS
    I had a pin hole leak in my condensor coil when mine was leaking. Look there too!
  6. #6 Re: Common AC Leak Points or Failure Grand Prix
    Never Never Land
    hmmm..im gonna take my UV light tomorrow night and check there too..thanks for the idea Rynoman
  7. #7 Re: Common AC Leak Points or Failure Grand Prix
    North Jersey
    so what does it mean when your car has a/c but absolutely zero heat?
  8. #8 Re: Common AC Leak Points or Failure Grand Prix
    Never Never Land
    you have absolutely zero freon..or a bad compressor
  9. #9 Re: Common AC Leak Points or Failure Grand Prix
    North Jersey
    well on a lazy summer day i'll poke at it a lil bit and see what it is but at least i have a good idea now
  10. #10 Re: Common AC Leak Points or Failure Grand Prix
    Never Never Land
    WAIT!!! i read that completely wrong. Your car has a/c but no heat? Correct? I thought i read it the other way.
  11. #11 Re: Common AC Leak Points or Failure Grand Prix
    North Jersey
    keep in mind i have dual zone, and i have almost heat on driver side and ice cube air on the other. BUT i have A/C. on both sides.
  12. #12 Re: Common AC Leak Points or Failure Grand Prix
    Never Never Land
    i know absolutely nothing about the dual zone..im assuming its digital since your car is a 99
  13. #13 Re: Common AC Leak Points or Failure Grand Prix
    Troy OH
    probably a bad heater control valve, not letting coolant get into the heater core
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    14.7psi is atmospheric pressure, it won't leak itself into a vacuum lol
    /threadjack.
    OP, if it's coming out to the point where you can hear it, i would imagine you could see the UV dye or notice a pretty big hole. a bad compressor would lead to no cold air, and it would also sound like sh!t. if you charge it and it blows cold, you probably just have a major leak instead of a broken part. you could try replacing the lines going in to and coming out of the compressor and then pulling a vacuum/charging/see if it works. just check all of your parts really well to make sure the leak isn't in the condenser, etc. i'd hate to do the same job twice
  14. #14 Re: Common AC Leak Points or Failure Grand Prix
    Topeka, KS
    No Prob basically just follow the lines with a uv light and glasses wherever it goes you look. I hate HVAC BS. Mines not working again. Last time i had issues with it, it took me 600 bux to get it right again.
  15. #15 Re: Common AC Leak Points or Failure Grand Prix
    Troy OH
    keep in mind that gauge pressures don't tell you a whole lot about the amount of refrigerant in a system just because of the nature of gases. if you really wanna test to see if you're low on refrigerant, open all the doors to give the system an infinate cooling load and listen to the compressor. if it cycles on and off quickly, you're low on refrigerant.
    Last edited by Poil336; 04-19-2011 at 12:09 AM. Reason: refrigerant is not equal to coolant
  16. #16 Re: Common AC Leak Points or Failure Grand Prix
    Never Never Land
    Quote Originally Posted by Poil336 View Post
    HAHAAHAHAH WOOOOOWWWWW...no wonder, thats makes perfect sense..i NEVER thought of that...so long story short..im loosing ALL my freon lol..im soo dumb for not rememerbing that atmospheric pressure is 14.7
  17. #17 Re: Common AC Leak Points or Failure Grand Prix
    Topeka, KS
    keep in mind that gauge pressures don't tell you a whole lot about the amount of refrigerant in a system just because of the nature of gases. if you really wanna test to see if you're low on coolant, open all the doors to give the system an infinate cooling load and listen to the compressor. if it cycles on and off quickly, you're low on refrigerant.
    Sh!t my compressor won't even turn on right now lol. But i'm not gonna hi-jack your thread man. Good luck!
  18. #18 Re: Common AC Leak Points or Failure Grand Prix
    Troy OH
    if you paid 600 bucks to get it fixed and it's not fixed, they owe you lol
  19. #19 Re: Common AC Leak Points or Failure Grand Prix
    Topeka, KS
    This was done 5 years ago man. When i bought the car in 05 the a\c didn't work. I got it going later that year.
  20. #20 Re: Common AC Leak Points or Failure Grand Prix
    May 2015
    Quote Originally Posted by jerZcavy4120 View Post
    Does the heat come on when you have it turned all the way up and does the DIC work? I had this same problem. My heater only worked when it was turned to the highest setting and my DIC didn't work. I replaced the ignition switch and it fixed both problems
  1. Finding Grand Prix parts or Grand Prix's in Junkyards near you!
  2. 93 Grand Prix stalling, running hot, coolant leak
    By thehollowaytape in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-07-2011, 10:46 PM
  3. 1999 Grand Prix Transmission leak
    By sdilliha in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2010, 11:56 AM
  4. Common Grand Prix problems?
    By TronCarter in forum General Tech Discussion
    Last Post: 03-04-2009, 04:38 PM
  5. 2002 Grand Prix - Right Rear Brake Leak
    By johngandersonjr in forum Brakes/Suspension/Chassis
    Last Post: 12-18-2008, 09:43 PM
