Thread: Common AC Leak Points or Failure Grand Prix
Results 1 to 20 of 22
  1. #1 Re: Common AC Leak Points or Failure Grand Prix
    Troy OH
    keep in mind that gauge pressures don't tell you a whole lot about the amount of refrigerant in a system just because of the nature of gases. if you really wanna test to see if you're low on refrigerant, open all the doors to give the system an infinate cooling load and listen to the compressor. if it cycles on and off quickly, you're low on refrigerant.
    Last edited by Poil336; 04-19-2011 at 12:09 AM. Reason: refrigerant is not equal to coolant
  2. #2 Re: Common AC Leak Points or Failure Grand Prix
    Topeka, KS
    Quote Originally Posted by Poil336 View Post
    keep in mind that gauge pressures don't tell you a whole lot about the amount of refrigerant in a system just because of the nature of gases. if you really wanna test to see if you're low on coolant, open all the doors to give the system an infinate cooling load and listen to the compressor. if it cycles on and off quickly, you're low on refrigerant.
    Sh!t my compressor won't even turn on right now lol. But i'm not gonna hi-jack your thread man. Good luck!
  1. Finding Grand Prix parts or Grand Prix's in Junkyards near you!
  2. 93 Grand Prix stalling, running hot, coolant leak
    By thehollowaytape in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-07-2011, 10:46 PM
  3. 1999 Grand Prix Transmission leak
    By sdilliha in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2010, 11:56 AM
  4. Common Grand Prix problems?
    By TronCarter in forum General Tech Discussion
    Last Post: 03-04-2009, 04:38 PM
  5. 2002 Grand Prix - Right Rear Brake Leak
    By johngandersonjr in forum Brakes/Suspension/Chassis
    Last Post: 12-18-2008, 09:43 PM
