Thread: performance shift
Results 1 to 20 of 23
Scott B performance shift 06-26-2008, 08:26 PM
archemedes Re: performance shift 06-26-2008, 10:19 PM
Preotic Re: performance shift 06-26-2008, 11:14 PM
TCO Re: performance shift 06-27-2008, 02:15 PM
IndeedSS Re: performance shift 06-27-2008, 03:18 PM
blowfishRus6 Re: performance shift 06-26-2008, 11:23 PM
GeddyLee Re: performance shift 06-27-2008, 12:59 AM
IndeedSS Re: performance shift 06-27-2008, 07:33 AM
GeddyLee Re: performance shift 06-27-2008, 07:51 AM
Sabrewings Re: performance shift 06-27-2008, 08:47 AM
Reptile Re: performance shift 06-27-2008, 09:38 AM
GeddyLee Re: performance shift 06-27-2008, 11:36 AM
GTP00Matt Re: performance shift 06-27-2008, 12:33 PM
Sabrewings Re: performance shift 06-27-2008, 12:47 PM
GeddyLee Re: performance shift 06-27-2008, 01:58 PM
webracin Re: performance shift 06-27-2008, 08:20 PM
Myprixxx Re: performance shift 06-27-2008, 04:36 PM
Ninjo Re: performance shift 06-28-2008, 09:41 PM
Sabrewings Re: performance shift 06-28-2008, 09:49 PM
Ninjo Re: performance shift 06-29-2008, 07:26 PM
IndeedSS Re: performance shift 06-29-2008, 08:19 PM
IndeedSS Re: performance shift 06-29-2008, 08:37 PM
IndeedSS Re: performance shift 06-29-2008, 08:40 PM
  1. #1 Re: performance shift
    St. Louis Mo.
    Quote Originally Posted by Reptile View Post
    Partially right. The speed limiter is set up in the spark and fuel tables, not the transmission settings.
    DOH! Spanks for pointing that out sir...........
    Speaking of spark................plugs......................
    James Shafer
    St. Louis MO
  2. #2 Re: performance shift
    SE Level Member GTP00Matt's Avatar
    May 2008
    Delavan, MN
    Quote Originally Posted by Preotic View Post
    They don't have the performance shift after 99.......
    My '00 GTP has it right on the shifter like normal.
    So forgive me, I'm new i guess only owned it for 2 months, when on performace shift there is no speed limiter? Or is it just raised up higher? Don't really need to go that fast but just curious.
    2000 GTP coupe, totally stock
    1995 Chevy K2500 6.5 TD 4" straight pipe 285 BFG's on 16x8 American Racing Nitro's
  3. #3 Re: performance shift
    Barksdale AFB, LA
    Speed limiter is there based off your stock tire speed rating. Going to performance shift wouldn't magically swap tires on your car, so I highly doubt GM upped the overall speed limiter for performance shift. They may have extended some shift points, but I doubt your final limiter was lifted.
    2009 Subaru Impreza WRX STI
  4. #4 Re: performance shift
    St. Louis Mo.
    Quote Originally Posted by Sabrewings View Post
    Well I got that from the Article that had the wiring setup for the Performance switch. I will try and track it down and reread it. Maybe I mistook what they said *shrugs*
    ****EDIT****
    I went to the Quebec Grand Prix Forum boards where I originally got the article, but the person who posted the pictures through his own personal web account no longer has them posted Figures!!
    James Shafer
    St. Louis MO
  5. #5 Re: performance shift
    GTX Level Member webracin's Avatar
    Arkansas
    Very true.....the speed limiter is there as a lawsuit prevention tool by the car manufacturer. If your car came with H rated tires on it from the factory, your speed limiter will be set to under 130MPH. If you change tires to a V rated tire, it will still be under 130MPH unless you have a some type of PCM editing program/tool. Be very careful when editing your speed limiter. If you choose to increase it to say 255MPH, and you are runing H rated tires, and make some long runs at 135MPH, you do run the risk of the tires coming apart. You should never drive faster than the speed rating of your tires for any length of time.
    Performance shift only effects the line pressure (firmer shifts) and the time between shifts (how fast it will shift). Anything else, such as:
    Higher or lower RPM's at the shift point
    Speed limiter increase or decrease (my teenager learned about this one. Hers is limited to 75MPH and I told her if she gets a ticket in town, I will lower it to 35MPH and she wont be able to take the interstate anywhere)
    Higher or lower MPH at the shift point
    And a whole slew of other things like Torque Management.
    If your going to adjust this stuff, ALWAYS us a 400RPM buffer, meaning if you want the car to shift at 6000RPM, set your tune to 5600RPM. By the time the car gets the signal to shift (@5600RPM) and everything switches over you will be at 6000RPM.
    2000 was the last year for STOCK performance shift by the way.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Performance shifting
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 06-01-2008, 08:58 PM
  3. Performance Chips???
    By philip09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2008, 04:19 PM
  4. performance shift light bulb
    By prostreet in forum Off Topic Discussion
    Last Post: 03-12-2008, 09:29 PM
  5. why did they get rid of the performance shift ?
    Last Post: 01-17-2008, 02:18 PM
