Thread: Please Help Anybody!! GP GT 3.8
Results 1 to 20 of 34
  1. #1 Please Help Anybody!! GP GT 3.8
    SE Level Member nickdemio's Avatar
    STL
    Man...this car is driving me crazy! Got the codes read on my car and it was saying MAF sensor-Evap Purge solenoid and Both o2 sensors....so i went to buy a brand new MAF sensor and put it on...went to advanced auto and got the codes erased & the service engine light came back on...got the codes read again and the o2 sensors went away..but the evap & MAF sensor code says pending..so do i need to drive the car a certain amount of miles before it registers the new piece???
    2001 GP GT
  2. #2 Re: Please Help Anybody!! GP GT 3.8
    check your gas cap to make sure it's tight.
  3. #3 Re: Please Help Anybody!! GP GT 3.8
    STL
    ok..i'll check that! but what does it meaning when the codes come up as "Pending"?
    2001 GP GT
  4. #4 Re: Please Help Anybody!! GP GT 3.8
    Charles City, IA
    It means it has not failed the test yet, but is expected to fail.
    SMGPFC Two Nipple General
  5. #5 Re: Please Help Anybody!! GP GT 3.8
    STL
    Hmmm...so why would the MAF sensor code come up as "Pending" if i jus put a brand new one in today? Do i have to drive a certain amount of miles before the computer registers the new part? Im lost...
    2001 GP GT
  6. #6 Re: Please Help Anybody!! GP GT 3.8
    Charles City, IA
    It might not have been the problem. A bad map sensor could also trip the maf code and 02 sensor codes find the step by step diagnostics for your codes and go threw them instead of throwing parts at the car.
  7. #7 Re: Please Help Anybody!! GP GT 3.8
    Mine and my grandma's threw the maf code when the gas cap wasn't tight so i figured start there it's free lol
  8. #8 Re: Please Help Anybody!! GP GT 3.8
    Could be a bad purge canister thats sitting on the back of the blower...it made my Mom's LeSabre go all crazy
  9. #9 Re: Please Help Anybody!! GP GT 3.8
    STL
    Ok...i also read on here in other threads...that a dudes car was throwing a P0102 & P0443 code and it was a bad fuse....cuz the MAF and EVAP or on the same fuse...i think he said like mini fuse 21 underhood and it should be a 15A...so i checked and the fuse was blown..so i swapped it out with a new one...turned the car on and it bounced a lil bit and normaled out..so i was thinking maybe i need to reset the codes for it to register all the way..so i jus unplugged the negative wire to the battery..waiting to hook it back up..hope this helps!!! I believe he had a 2000 GP GT supercharger...would our underhood fusebox be situated the same?
    2001 GP GT
  10. #10 Re: Please Help Anybody!! GP GT 3.8
    STL
    I jus have a non superchager 3800 series II
    2001 GP GT
  11. #11 Re: Please Help Anybody!! GP GT 3.8
    just unhook both pos and neg and touch them together for a few seconds then hook it back up and you should be good to go.
  12. #12 Re: Please Help Anybody!! GP GT 3.8
    STL
    ok..ima do that! what does this do?
    2001 GP GT
  13. #13 Re: Please Help Anybody!! GP GT 3.8
    resets the computer
  14. #14 Re: Please Help Anybody!! GP GT 3.8
    STL
    well i did the neg & pos wire tocuh...and the service engine light is still on...but the car seems to be acting rite...smh..what should i do?
    2001 GP GT
  15. #15 Re: Please Help Anybody!! GP GT 3.8
    scan it and see what the code is. Was it on right away or did it come on after the car was running for a little bit?
  16. #16 Re: Please Help Anybody!! GP GT 3.8
    STL
    I got unhooked the wires...touched them for a few seconds..plugged them back up..and started the car...and the light was on, like it neva went off...and now my mpg is horrible..its at like 9.9mpg and it was at like 15..which is still bad..im wondering if i even did it rite! And the codes that are coming up are P0102 & P0443(MAF and EVAP purge solenoid)
    2001 GP GT
  17. #17 Re: Please Help Anybody!! GP GT 3.8
    Jersey
    if ur going by the Dic, its because u un-hooked the battery. Its hardly accurate anyway
    16' wrx sti- stock
  18. #18 Re: Please Help Anybody!! GP GT 3.8
    STL
    Thats wasup 99grandprixgt!!! well..do u know anything about the codes come up as "pending, after i put the new MAF sensor??smh..cuz at 1st...when the bad MAF was in..it was throwing a P0102, P0443 and two more codes..that were the o2 sensors(bank 1 & bank 2)..then i put the new one in and the o2 sensor codes went away..but the P0102 & P0443 are saying "pending" wth is wrong with this car?? lol...
    2001 GP GT
  19. #19 Re: Please Help Anybody!! GP GT 3.8
    I cleaned this up...not doing it again.
  20. #20 Re: Please Help Anybody!! GP GT 3.8
    STL
    ok..my bad for the last post...didnt know u erased his post..i thought u were taking his side...just be fair is all i ask..he started this..so u should have been directing the comment towards him..not me...thats all..i even told him..i didnt have no problems with him...wth
    2001 GP GT
