Thread: knock issue
Results 1 to 13 of 13
  1. #1 knock issue
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    my mods are...high compression block, xp cam, springs, speed daddy headers, gen 5, meth injection, northstar, 3.29 gears, and 3.1 pulley...problem is im getting bursts of knock at shift...itll hit 9 and drift down to zero but half the time it wont do it at all. took the timing down to 13 and ran the larger meth nozzle with very little difference. what could be causing this?
  2. #2 Re: knock issue
    Waukesha, WI
    false knock maybe?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: knock issue
    Feb 2010
    somewhere cold
    ive heard of the term knock burst...i believe its that...and a 9 for false knock...thats a bit high but also ive never run 3.29 gears and this horsepower before
  4. #4 Re: knock issue
    Waukesha, WI
    hm never heard of knock burst, lol time to google
    RayRay
    92 Turbo miata
    02 lexus is300
  5. #5 Re: knock issue
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Knock burst is usually when your just entering boost. You get a degree or two. Being at your shift Id assume its maybe a lean spike. Or maybe false. take the blower belt off see if it does it. Add some octane boost. does it go down or disapear?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: knock issue
    Feb 2010
    somewhere cold
    well it spikes a nine at best and takes a few seconds, maybe three at most, to drift down to 0 where it stays. can false knock actually register that high and take that long to fall back? i first assumed false with as hard as the tranny shifts but the number seemed really too high for false and took to long to disipate unless im wrong as im very new to this setup
  7. #7 Re: knock issue
    Feb 2010
    somewhere cold
    took her out again and it also does it everytime i enter boost but for some reason it only flares to 4 now and settles almost immediatly and i did about ten hard pulls with it...also seems to have a coil pack goin as it studders just a little at wot
  8. #8 Re: knock issue
    Why and the fudge is your timing so low?
    I think its more than a false knock or whatever issue.
  9. #9 Re: knock issue
    Hagerstown,Md
    Whats your AFR? Studder at WOT sounds like a lean issue. One thing id suggest is droping PE to 27 28 percent. that way its fueling right before you hit boost
  10. #10 Re: knock issue
    Feb 2010
    somewhere cold
    thanks for the responses guys....first afr is 10.5 at wot. Second the cranked the timing that low because of the knock...my first run without the meth my timing was 18 and it flared a 13 on the knock scale...i ran it down to 13 and added the meth and now its down to what i stated earlier...i figured the studder was a coil pack acting up and was gonna buy a new one and rotate them around to see if i can find the bad one as my resistnces are all withing range if not ill try the wires
  11. #11 Re: knock issue
    why dont you tune it without the meth first, then add the meth in and add timing/boost? it doesnt make sense that youre throwing all these variables at it and making it difficult on yourself.
    also, with a 10.5 AFR youre running too much meth. way too much. think of it as a secondary fuel. you dont want a crappy AFR, ever.
  12. #12 Re: knock issue
    Feb 2010
    somewhere cold
    i was gonna tune without the meth bio but with the knock where it was and still is im hoping it buys me some time to figure out whats wrong before i blow the motor again...also found a very small leak on the front header...could this cause that much knock?
  13. #13 Re: knock issue
  1. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  2. knock
    By 04BlackComp_G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2011, 12:27 AM
  3. 00 GT rod knock
    By Sameyeam in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2010, 05:57 PM
  4. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  5. Bad EGR = knock?
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-31-2008, 07:13 PM
