Thread: GPS Mounting
Results 1 to 3 of 3
  1. #1 Re: GPS Mounting
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Does it have the suction cup to hold it up?
    If it does, I like to put it on the glass for the sun roof. Put it all the way to the right and towards the hood.
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: GPS Mounting
    TDCRacing
    Guest
    I satrted off by lifting up the bubber mat that lays down inside the ''cubby'' hole and cleaning the hard plastic part really good that lies beneath the rebber mat.. next i put the hard plastic circle piece that the suction cup ataches to that comes with the gps..peeled off the film to reaveal the sticky tape that is on the back of it...and stuck it inside the plastic cubby hole (make sure you have it mounted where you want it before doing this). Next i hard wired the gps into the car by connecting it to the power source supplied by the cig lighter on the passanger side console. I just ran the wires through the back of the console so nothing can be seen. If i want to take the gps out all i do is disconnect the gps from the power plug and remove it from the suction cup stand. and you can always remove the suction cup stand put the rubber mat back over the hard plastic peice and throw the wire in back of the console and no body will ever know it's there....heres a pic...this is the best place for it trust me....Excuse the very dirty car
  1. ballast mounting
    By Toasty in forum Visual/Body Modifications
    Last Post: 03-31-2008, 12:40 AM
  2. How to make a nicer aftermarket radio mounting kit. [*]
    By s1795so2 in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 10:45 AM
