Thread: HVAC troubles
Results 1 to 9 of 9
  1. #1 HVAC troubles
    Altoona, Pa
    About a year ago my heater/ac started to act a little weird. At first it wasn't working at all. Then one day it started to work again, but not correctly. It would blow out the heat/ac, stop, and restart again. The intervals are never consistant and it seems rather random. Well, recently it started blowing very weakly, just enough to feel air coming out. From time to time it will work right for a few minutes, and then go back to not working again. I was told this is probably a problem with the resistor?
    Any Ideas?
    Thanks!
    Car Details
    2004 Grand Prix GT - 3.8L V6 all stock
  2. #2 Re: HVAC troubles
    Oct 2008
    Calgary, Alberta
    Does the fan blow ok on high speed?
    - Normaly if it is the resistor pack high speed works fine.
    My gtp with auto climate controll (digital fan controller 7 speeds) had issues with where the air was directed as there was a break in the vacumme control line going through the wiring harness by the battery. I ended up replacing bthat line with a shorter one routed into the cabin beside the transmission selector cable, in the same gromet, made out of brake line tubing.
  3. #3 Re: HVAC troubles
    Altoona, Pa
    I always keep the blower to full. And no, it still kicks on and off for some reason, but when its on, it works good.
  4. #4 Re: HVAC troubles
    Charles City, IA
    Change your cabin air filter, and you probably need a new blower motor. To change the cabin air filter
    1. Turn on you wipers and stop them in the up position by turning off the key
    2. open hood
    3. Remove the 3 IIRC panel clips holding the plastic on the passenger side where the wiper arm bolts in.
    4. remove that piece and you will see your clogged cabin air filter.
    SMGPFC Two Nipple General
  5. #5 Re: HVAC troubles
    Altoona, Pa
    I never thought of that... you sir, may be a genius
  6. #6 Re: HVAC troubles
    Charles City, IA
    I have put 3 blower motors,1 resistor,2 cabin filters, and one splash shield in w-bodys in the last week at work.
  7. #7 Re: HVAC troubles
    North Dakota
    Anyone had any success doing this? My problem can be explained exactly as the OP described it, same year and everything.
  8. #8 Re: HVAC troubles
    North Dakota
    Quote Originally Posted by white04gt View Post
    Update: replaced the resistor last week and it wasn't the problem, ordered a new blower motor and this turned out to be the fix. super easy fix, glad i found all this info, great forum.
  9. #9 Re: HVAC troubles
    Apr 2011
    up state ny
    Quote Originally Posted by ajramos26 View Post
    Any Ideas?
    Thanks!
    Car Details
    When you say, "It wasn't working at all, and started to work again" Was there power at the HVAC control unit? I have a 2000 GP and it just started having these power on/off issues with the trip computer and AC/Heater control unit. Both units go dead (no LED's on either display) and all on it's own power is restored, maybe during the same drive or two days later. A random thing here.
  1. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  2. Top Swap Troubles??
    By Pontiacman76 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-13-2010, 09:39 PM
  3. map sensor troubles
    By Schaum in forum General Tech Discussion
    Last Post: 07-07-2010, 06:28 PM
  4. Electrical Troubles
    By Orozco in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 12:00 AM
  5. Need some help with amp and sub troubles
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 02:51 AM
