View Poll Results: witch ones would you get?
Voters
18. You may not vote on this poll
  • WBS Headers
    12 66.67%
  • ZZP Headers
    2 11.11%
  • TOG Headers
    4 22.22%
Thread: headers
Results 1 to 20 of 21
  1. #1 headers
    SE Level Member kurt5153's Avatar
    Apple Valley,Ca 92308
    hey guys im shopping for my headers n saw these two new headers was wondering what you thought. i'm unsure witch ones to get. thxs!
    1}WBS Headers
    W Body Store
    2}ZZP Headers
    ZZ Performance
    back up choice
    3}TOG headers
    The Other Guys Exhaust Headers: 3800 Performance
  2. #2 Re: headers
    Only new one is the first set...the others have been around awhile.
    if I had the money...I'd get ZZP's...but I'd never spend that much money on headers for a WBody.
  3. #3 Re: headers
    Mullet Member Wotgtp's Avatar
    Connecticut
    My personal choice would be getting SLP headers, new or used. I love them. Hoiwever if I had to choose from the three it would be WBS.
  4. #4 Re: headers
  5. #5 Re: headers
    I've tossed up info on headers and installs in the past, and it never seems to get old. Here ya go.
    SLP's/SD's: Very easy to install, the slip fit is great. Ensure if you have the SD's that you plan for the O2 hitting the side of the tunnel/firewall and you pick up the band like torca clamps. FWIW I love to do the installs on these two types of headers.
    Togs: Installers nightmare of headers. At least the ones I've done. The flange for the crossover to rear header is right at the trans dipstick. You have to bend the tube, then have three people on hand. One on top, another on bottom of the flange and a third to get the beers. IMO having the donut and flanges is bad, they are in the exhaust stream, a slip fit is nice flow IMO.
    WB/ZZP: honestly they look basically the same for shape to me. Overall an easy install like SD/SLP's without surprises. However the ZZP EGR relocation is a bit unnerving. You must bend that EGR tube a good amount and those tubes crack just being bolted to the LIM. Bending is not my favorite part. Otherwise.. good install.
  6. #6 Re: headers
    Pennsylvania
    TOGs install is kind of frustrating when you get to installing the crossover - the bolts are in the least convenient places possible. Then, once you get it installed, you have to re-tighten everything from underneath the car after it's heat-soaked a bit.
  7. #7 Re: headers
    Delaware, OH
    Honestly just save a few hundred and buy speed daddy headers. I spent an extra $40 on gaskets and clamps and have no problems.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  8. #8 Re: headers
    GT Level Member starscream5000's Avatar
    Kentucky
    Since Speed Daddy's aren't on the list I'd have to choose WBS.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  9. #9 Re: headers
    Anyone see the WBS downpipe yet?
  10. #10 Re: headers
    Banned
    Mansfield, Ohio
    WBS downpipe, v-band and no retarded u bend in the dp!!!!!
  11. #11 Re: headers
    Thxs for the input guys, I haven't seen the WBS Do yet even tho I asked for a pic....
  12. #12 Re: headers
    A local bought a set...
    Having plenty 'o issues with the transmission dipstick.
  13. #13 Re: headers
    so they are TOGs with slip joints? damn...
  14. #14 Re: headers
    Makes sense.
    Otherwise bolting up the EGR would be impossible.
    One of the reasons why I hated my pacesetters.
  15. #15 Re: headers
    Pacesetter made the EGR tube in the rear header too small/shallow. Had they changed one simple thing the EGR would have fit like it came out of the factory.
  16. #16 Re: headers
    Topeka, KS
    FWIW I like my SSAC's.
  17. #17 Re: headers
    Oh fitting it in there wasn't my problem.
    the crossover made it impossible to do/undo the bolt.
  18. #18 Re: headers
    1/4" ratchet with pivoting head, a 3" extension and a shallow 10mm socket.
    Been there, won that battle.
  19. #19 Re: headers
    Wuts EGR?
  20. #20 Re: headers
    Jul 2008
    Tampa, FL
    i love my speed daddy's...but hey, i'm cheap...
  1. Headers
    By gxp05 in forum 5.3L V8 (LS4)
    Last Post: 11-08-2010, 09:42 AM
  2. getting headers. what do i all need?
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2010, 08:29 PM
  3. headers..
    By fremmy182 in forum General Tech Discussion
    Last Post: 09-15-2010, 11:06 PM
  4. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
