Thread: 2000 gp gt blower issues...any help?
Results 1 to 5 of 5
  1. #1 2000 gp gt blower issues...any help?
    Apr 2011
    magnolia
    i have a similar issure with the discussion. i have a 2000 grand prix gt 3.8 series 2. generally stock. just bought. my heat and ac worked just fine when i bought it a week ago. now when i turn the dial the heat nor the ac will blow out? all fuses are good for hvac and hvac hi all relays are good in the car. im hearing it could be my blower motor or my blower motor resistor. i know how to replace them both... but is theere anyway too test the resistor so i dont replace that first and that not be the problem? (just trying to save every penny possible for the thrasher shift kit and perf. chip) any insight would be greatly appreciated.
    thanks
  2. #2 Re: 2000 gp gt blower issues...any help?
    thrasher is out of business, I'd suggest doing more research for mods. Hopefully that'll save you some dough.
    Party on with your blower issue.
  3. #3 Re: 2000 gp gt blower issues...any help?
    Charles City, IA
    Um check for power at the resistor and the blower motor?...................
    SMGPFC Two Nipple General
  4. #4 Re: 2000 gp gt blower issues...any help?
    Nick..how do we do that?
  5. #5 Re: 2000 gp gt blower issues...any help?
    Donating Users madpat's Avatar
    Apr 2011
    New York
    I had the same problem in my 2001 SE, my blower motor completely died and I had to replace that, but I didn't bother changing the BMR (blower motor resistor).
    In the end I only had heat on #5 work, while 1-4 did not.
    The blower motor is located under the passenger side glove dash, you have to remove a panel and it is a very tight spot.
    The BMR is located right behind the actual blower motor.
    Test the power to both to find out which one, if not both are bad.
    Representing the 315 - CNY!!
  1. 2000 Grand Prix Tachometer/Trac Light/Stall Issues
    By ZackN in forum General Tech Discussion
    Last Post: 09-26-2013, 11:40 AM
  2. dexron 6 issues in a 2000 GTP
    By calvin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-19-2011, 08:53 AM
  3. Blower motor resistor issues
    By DarkCherry in forum General Tech Discussion
    Last Post: 11-11-2010, 01:52 PM
  4. 2000 GT Idle & Whine Issues
    By drewcruisin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2010, 10:53 PM
  5. 2000 Grand Prix Electrical issues
    By Stappen720 in forum General Tech Discussion
    Last Post: 09-24-2009, 06:32 AM
