Ok basically my dome lights do not turn on when the doors are opened. Also they don't turn on manually when there is no key in ingnition. If you turn the key to accessory then they will turn on manually, they also don't turn on when the dimmer switch is pushed all the way to the right. All the other lights work when the doors open and with the dimmer switch. Not sure what the problem is? If it's a fuse or what? Any thoughts?
