Thread: Why is my cruise control not working?
Results 1 to 11 of 11
  1. #1 Why is my cruise control not working?
    Dec 2008
    Michigan
    I got on the freeway and set my crusie control and everything was fine. Then I some guy got on my a$$ (I was doing 75 mph) so I got over and so did he so I "punched" the throttle and my cruise did not work after that.
    I tried to set it a few times after that and after my car sat for hours. I checked the 10amp fuse in the glove box, it's okay, and that's all I can think of.
    Just a side note, not sure if ya'll have this but whenever my cruise would engage I could hear some solenoid near the firewall click on. Was that bad? Did it finally break? Or does GM put loud solenoids in? It did this for years, but no problems.
    Please help, I'm driving to Chicago next weekend and dread not having cruise control. I'm wondering if it's in the wand itself.
  2. #2 Re: Why is my cruise control not working?
    HUDSON
    What year car do you have?
    I have a 2000 GTP.
    When my cruise would not work, it turned out to be the third brake light bulb/s.
    Have you checked the connection of the cable to the throttle body?
  3. #3 Re: Why is my cruise control not working?
    Apr 2011
    wisconsin
    same thing here,,,my cruise stopped I looked all over hell to figure out why
    then I noticed 1 of my brake lights were out, so I replaced the bulb and cruise was back to working
  4. #4 Re: Why is my cruise control not working?
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    x3
    check your bulbs
    come stop by the south side so you can see me car. i can set up a big cruise
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  5. #5 Re: Why is my cruise control not working?
    Houston
    When my cruise quit, it turned out to be the brake switch.
  6. #6 Re: Why is my cruise control not working?
    Dec 2008
    Michigan
    I have a 2000 GP GT
    Wow guys, I guess I'll check the brake light after work and see, LOL.
    I hope ya'll are right, I'll follow-up.
    iroc2: "come stop by the south side so you can see me car. i can set up a big cruise " what does this mean?
    KeithGTP03: "Brake switch"?
  7. #7 Re: Why is my cruise control not working?
    Like mentioned could be a bulb or brake switch, although it's doubtful that they kicked out that easily.
    The cruise module on the firewall isn't typically loud, well...I can't say that I've ever heard one.
    Check where the cruise cable attaches to the throttle body. If that clip broke, then it won't be able to work the throttle.
  8. #8 Re: Why is my cruise control not working?
    Dec 2008
    Michigan
    Allright I paid a shop to diagnose it and they said it was the cruise control module which is around $330. They wanted $580 including the diagnosing fee to fix it. yeah right.
    Could I assume it really is the module and attempt to fix it myself. Maybe go to the junkyard and cut one off. Anyone ever changed one of these?
    I can check the throttle cables but it was a reputable place (Fire$tone).
  9. #9 Re: Why is my cruise control not working?
    Houston
    This is used but its a helluva lot cheaper.
    2000 PONTIAC GRAND PRIX CRUISE CONTROL MODULE 14297 MILES
  10. #10 Re: Why is my cruise control not working?
    Dec 2008
    Michigan
    The problem is solved. I bought a $45 junkyard cruise control module off of a Grand AM and everything works fine. Keep in mind Impala, Monte Carlo, Intrigue, Buicks, etc. have similiar parts. I replaced it myself in 15 minutes. The yellow cloth cable broke. Thanks for all the help.
  11. #11 Re: Why is my cruise control not working?
    Apr 2011
    wisconsin
    all at a cool savings of $540 bucks....nice
    glad it worked out
  1. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  2. Cruise Control Help !!!
    By avenger33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2010, 07:33 PM
  3. Cruise Control
    By TeeWX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2010, 07:16 PM
  4. cruise control
    By Wadeb79 in forum Off Topic Discussion
    Last Post: 02-01-2009, 12:18 PM
  5. Cruise Control stopped working
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 07-03-2008, 11:48 PM
