Thread: Smoke from rear of engine compartment
Results 1 to 3 of 3
  1. #1 Smoke from rear of engine compartment
    Apr 2011
    Baton Rouge
    Hi I am new to this forum but I have read alot from it. Anyway I recently replaced both valve cover gaskets and grommets on my 98 GTP due to seeing smoke from both those areas. Anyway, the smoke in front is gone but it is still smoking in the rear at a reduced rate. It seems I did not get the install down on the rear cover. I am replacing my supercharger coupler soon and I am wondering what to do about the smoke from rear valve cover area. Am I stuck buying another gasket set? Well thanks for your help or suggestions. Back to the heat of south Louisiana.
  2. #2 Re: Smoke from rear of engine compartment
    it maybe just left over oil burning off, did you degrease the engine before you did the vc gaskets? if not try that.
  3. #3 Re: Smoke from rear of engine compartment
    Apr 2011
    Baton Rouge
    Ill try it out thanks.
  1. Burning smell from engine but no smoke?
    By Importz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2011, 09:50 PM
  2. Pours blue smoke, wont idle, check engine light flashes!?
    By 1fastz71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2010, 09:13 PM
  3. Ticking/knocking sound in engine compartment
    By 200GpGt in forum General Tech Discussion
    Last Post: 04-17-2010, 03:54 PM
  4. Engine Compartment Sound/Noises I need diagnose ASAP!!!
    By FlaminWhite97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2010, 09:56 PM
  5. Swap 3.8 (L67) into 3.1 engine compartment?
    By jerricho in forum General Tech Discussion
    Last Post: 05-17-2008, 12:07 AM
