Thread: Replacing Power Steering Pump
Results 1 to 18 of 18
  1. #1 Replacing Power Steering Pump
    Apr 2011
    Toronto
    Hey! I've got a 2000 GTP with 100,000 miles on it. The power steering has been making a whining sound for a little while now and the fluid is constantly leaking. I have tried to top up the fluid, use Lucas to seal and still the sound and leak continues. I'm pretty sure the pump is shot, so now the question is how to repair? I would like to avoid bringing to a mechanic, so does anyone know how easy this process is? The engine bay is so jammed I figure I have to remove some stuff, but any help/suggestions would be greatly appreciated! Thanks
  2. #2 Re: Replacing Power Steering Pump
    Omaha, NE
    Its a fairly simple process that can be done with a minimal tool set. After you undo the belts using the tensioner, remove the alternator and the coolant passage that sits below it. Then unbolt the power steering pump, disconnect the lines and do the reverse to put it all back together.
  3. #3 Re: Replacing Power Steering Pump
    Minnesota
    remove the passenger side wheel too it makes it alot easier to alot of the work through the wheel well
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  4. #4 Re: Replacing Power Steering Pump
    Omaha, NE
    ^True.
    Don't forget new coolant elbows for that passage. YOU WILL Break the old ones. They are under $5 for the pair at autozone.
  5. #5 Re: Replacing Power Steering Pump
  6. #6 Re: Replacing Power Steering Pump
    Apr 2011
    Toronto
    Thanks for replying and sorry Mod for posting in wrong section. Was looking for a how to guide as well LOL. Any other tips would be greatly appreciated tho! Trying to avoid paying the mechanic
  7. #7 Re: Replacing Power Steering Pump
    Apr 2011
    Toronto
    Would you recommend buying a new, used or rebuilt power steering pump?
  8. #8 Re: Replacing Power Steering Pump
    new
  9. #9 Re: Replacing Power Steering Pump
    Omaha, NE
    Go to GPONA and log in (register if you haven't already). On the top it says service manual, its a copy of the GM service manual that they host and has great instructions for things like this as well as diagnostic info, etc.
  10. #10 Re: Replacing Power Steering Pump
    Omaha, NE
    New or Remanufacured. Check out rock auto then google rock auto discount codes, you should be able to get one pretty cheap that way.
  11. #11 Re: Replacing Power Steering Pump
    Apr 2011
    Toronto
    damn, GM Service Manual link seems to be down.. Will try again later though. Thanks for all the posts!
  12. #12 Re: Replacing Power Steering Pump
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    The hoses are probably shot too, which may have been the cause for your fluid level to drop.
  13. #13 Re: Replacing Power Steering Pump
    Apr 2011
    Toronto
    The leak and drop in fluid level wouldn't be just from the pump? There's probably other issues as well?!
  14. #14 Re: Replacing Power Steering Pump
    Illinois
    Quote Originally Posted by AGP View Post
    Yes. Listen to mechguy. I'm going through the exact same thing as you are right now. And after changing the power-steering pump, I am in the process of finding the source of the leak because it wasn't the pump. Find the leak first, or have someone with a lift get it up in the air so they can maybe see it better, find and fix the leak before going through the expense of a new pump. May need one, but take it from me, changing the pump doesn't necessarily fix the leak. I got to get to work right now, but do that first, and I'll tell you the steps I used to get the pump changed if you need to. Everyone here was very helpful when I changed mine, so others may have good ideas for you as well.
  15. #15 Re: Replacing Power Steering Pump
    Denver
    I think he's saying it would be a good time to replace the hoses too.
    If you're going to open the hydraulic circuit, might as well get it all up-to-date in one fell swoop.
  16. #16 Re: Replacing Power Steering Pump
    Apr 2011
    Toronto
    Thanks Quickster. Good to know you just went through the same thing. Did you end up fixing completely? I will prob take it to a garage this weekend to put on a hoist. I'm pretty sure its the pump though - the pool of fluid is right under the pump and when I went under it didn't seem to be leaking from the lines. The whining sound is so annoying I gotta resolve asap. Also the burnt smell is horrible walking past after parking - not to mention the dirty looks from the other condo residents. lol
  17. #17 Re: Replacing Power Steering Pump
    Illinois
    I'm hoping to find the leak this week-end. If not, I'll take it somewhere to get it up on a hoist and get some help finding it.
    Hopefully it's just your ps pump. It's not that hard to change. An extra pair of hands are helpful, but if not, still not that hard. Keep us updated.
  18. #18 Re: Replacing Power Steering Pump
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    My p/s pump is leaking too! I just stuck my hand down (underneath the pump) there to feel around and the metal tube that goes to the hose was leaking. It looks like the clamp moved up the hose. Therefore, the clamp isnt all the way down, over the metal tube. So, there's a little leak right there.
    I know this is a old thread but I wanted to share my problem lol
  1. Power Steering Stiff After New Pump
    By brandonl2000 in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2011, 01:05 PM
  2. 99 GT power steering pump
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-10-2011, 11:13 PM
  3. Need New Power Steering Pump?
    By brandonl2000 in forum General Tech Discussion
    Last Post: 12-05-2010, 01:59 PM
  4. power steering pump
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 04:26 PM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
