Yes. Listen to mechguy. I'm going through the exact same thing as you are right now. And after changing the power-steering pump, I am in the process of finding the source of the leak because it wasn't the pump. Find the leak first, or have someone with a lift get it up in the air so they can maybe see it better, find and fix the leak before going through the expense of a new pump. May need one, but take it from me, changing the pump doesn't necessarily fix the leak. I got to get to work right now, but do that first, and I'll tell you the steps I used to get the pump changed if you need to. Everyone here was very helpful when I changed mine, so others may have good ideas for you as well.
