Thread: Urgent read ! Oil oil oil>
Results 1 to 14 of 14
  1. #1 Urgent read ! Oil oil oil>
    GT Level Member AmericanRiceEater's Avatar
    New York
    Hey this is pretty urgent . My car just stalled a bit ago because i was running it on low oil in the hot sun. I bought new oil and put 5W in with the little bit of 10W that was left. My car is running good but is that bad that i mixed a lot of 5W with a little bit of 10W. Or should i say will it eventually dilute together?
  2. #2 Re: Urgent read ! Oil oil oil>
    SE Level Member NashGT02's Avatar
    Davenport, IA
    Im no mechanic but I think you will be ok for now but dont run forever on it. Go get it properly taken care of.
  3. #3 Re: Urgent read ! Oil oil oil>
    No you are fine. today all oil is may better than before, 5w30 will work fine but i just like to use what the engine says to use. Really right now you prolly have it running with 7w30 or 8w30 with the mix you have. You will be fine.
  4. #4 Re: Urgent read ! Oil oil oil>
    Jul 2008
    sumter,south carolina
    id be more concerned about why the car was that low on oil. mixing it wont hurt anything.
    02 GTP with mods 05 GP for DD
  5. #5 Re: Urgent read ! Oil oil oil>
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    ^^X2
    When was the last time you pulled the dipstick?
    How much oil did you have to add?
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  6. #6 Re: Urgent read ! Oil oil oil>
    Apr 2009
    stockton ca
    if there was oil on the dip stick at all then your ok below that your ****ed
  7. #7 Re: Urgent read ! Oil oil oil>
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    i've been wondering why the series II calls for 10W-30 and the series III calls for 5W-30. what's the difference between the two engines? i figure it'd be safe even for my GTP to start running 5W-30.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  8. #8 Re: Urgent read ! Oil oil oil>
    Quote Originally Posted by torq455 View Post
    Todays oil are much better designed and can handle these engine better. It all comes done to better technology. I run what is says just because I want to, but it should not matter at all.
  9. #9 Re: Urgent read ! Oil oil oil>
    Dec 2008
    Alabama
    true. although there are many engines that are older that call for 5W-30. i just wondered why GM requires 10W-30 for series I and II 3800's. are their clearances and tolerances bigger for some reason? i don't understand why they wanted the oil thicker when cold. i think i'll start using the 5W-30.
  10. #10 Re: Urgent read ! Oil oil oil>
    Charles City, IA
    I have always used 5w-30
    SMGPFC Two Nipple General
  11. #11 Re: Urgent read ! Oil oil oil>
    Jul 2008
    5 30 in winter 10 30 in summer
  12. #12 Re: Urgent read ! Oil oil oil>
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    15w40 Semi Synthetic blend in everything I own that isn't 2 stroke or an ATV. I don't have oil related problems.
    You mixing, as already stated, won't hurt a thing.
  13. #13 Re: Urgent read ! Oil oil oil>
    i ran 10w40 in my car because i had low oil pressure issues.
  14. #14 Re: Urgent read ! Oil oil oil>
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Quote Originally Posted by SnowDrift View Post
    X2^
  1. Urgent help
    By milfadic in forum General Tech Discussion
    Last Post: 05-20-2010, 06:02 PM
  2. My Caliper iS StuCK!! Help its urgent.
    By nateberry in forum Brakes/Suspension/Chassis
    Last Post: 02-27-2010, 12:30 PM
  3. urgent is my tranny hooped
    By nascartech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2010, 11:41 PM
  4. urgent dead car
    By Sunstone in forum General Tech Discussion
    Last Post: 09-07-2008, 12:22 PM
  5. Urgent need of Help
    By Sunstone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2008, 01:22 PM
