Thread: GTP won't run with MAF SENSOR
Results 1 to 7 of 7
Drink gas GTP won't run with MAF SENSOR 04-06-2011, 08:48 AM
FordMan77 Re: GTP won't run with MAF... 04-06-2011, 09:30 AM
BillBoost37 Re: GTP won't run with MAF... 04-06-2011, 09:33 AM
blueguy Re: GTP won't run with MAF... 04-06-2011, 10:38 AM
Drink gas Re: GTP won't run with MAF... 04-06-2011, 05:24 PM
taman86 Re: GTP won't run with MAF... 04-09-2011, 01:27 AM
DanGTP Re: GTP won't run with MAF... 04-09-2011, 03:01 AM
  1. #1 GTP won't run with MAF SENSOR
    Apr 2011
    Bronston ky
    My 99 gtp will not run only for about three minutes with te sensor plugged I'n until you unplgue it , it will run fair but when u give it gas there is a bog and knocking when it builds boost , PLEASE!!! help
  2. #2 Re: GTP won't run with MAF SENSOR
    GrandPrix Junkie
    St. Louis
    Sounds like you need a new MAF. With it unplugged it is running off of preset tables and will not run its best, but will run. Don't drive it with the MAF disconnected unless you desparately have to. If you do, then it may be a good idea to remove the SC belt. I'm not an S/C guru but I swear I've read that here before.
  3. #3 Re: GTP won't run with MAF SENSOR
    You can drive on the tables, but don't go beating it. Drive as though you have part of it's leg cut off... nicey nice...
    I agree, you seem to need a maf sensor.
  4. #4 Re: GTP won't run with MAF SENSOR
  5. #5 Re: GTP won't run with MAF SENSOR
    Apr 2011
    Bronston ky
    It's a brand new one I have put two I'n the last three days I don't know whT else to really do
  6. #6 Re: GTP won't run with MAF SENSOR
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    iac sensor maybe?
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  7. #7 Re: GTP won't run with MAF SENSOR
    Feb 2008
    Check the voltage of the reference wire and make sure it is 5 volts. If it's much higher, you may be frying the new sensors. Possible electrical short somewhere?
  1. Best way to change O2 sensor/ECT sensor?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-23-2010, 09:36 AM
  2. TPS Sensor
    By Derrick4625 in forum Introductions/Noob Questions
    Last Post: 09-09-2010, 07:32 AM
  3. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  5. map sensor
    By bigbrotherk15 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2009, 04:12 PM
