Thread: GTP won't run with MAF SENSOR
Results 1 to 7 of 7
  1. #1 Re: GTP won't run with MAF SENSOR
    St. Louis
    Sounds like you need a new MAF. With it unplugged it is running off of preset tables and will not run its best, but will run. Don't drive it with the MAF disconnected unless you desparately have to. If you do, then it may be a good idea to remove the SC belt. I'm not an S/C guru but I swear I've read that here before.
  2. #2 Re: GTP won't run with MAF SENSOR
    You can drive on the tables, but don't go beating it. Drive as though you have part of it's leg cut off... nicey nice...
    I agree, you seem to need a maf sensor.
  1. Best way to change O2 sensor/ECT sensor?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-23-2010, 09:36 AM
  2. TPS Sensor
    By Derrick4625 in forum Introductions/Noob Questions
    Last Post: 09-09-2010, 07:32 AM
  3. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  5. map sensor
    By bigbrotherk15 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2009, 04:12 PM
