Thread: Windshield Wiper Pump Broke again.....
Results 1 to 7 of 7
  1. #1 Windshield Wiper Pump Broke again.....
    GT Level Member Egleone6's Avatar
    Springfield, Illinois, United States
    What is the deal. Does anyone else have this reoccurring problem? This is the 4th or 5th one I have had break. Between both GP's, I have spent toooo much money on this. Am I using a cheap part, or do these go out often?
    If my pics are not working, please email me, I may have moved the pics on a different page on Photobucket. Thanks
  2. #2 Re: Windshield Wiper Pump Broke again.....
    Saraland Alabama
    mines the original, do you tend to run out of fluid?
  3. #3 Re: Windshield Wiper Pump Broke again.....
    Nope. I can't tell you the last time I saw the low fluid light on. When I get a oil change, they fill it up. Is it hard to change? I should know how to change it after watching the mechanic fix it the first three or four timess.
  4. #4 Re: Windshield Wiper Pump Broke again.....
    Saraland Alabama
    very easy it doesn't even bolt in, it's a pressure fit pull the old one, put new in, and hook up hose and wire
  5. #5 Re: Windshield Wiper Pump Broke again.....
    How exactly do you change it? Does the battery need to be removed?`
  6. #6 Re: Windshield Wiper Pump Broke again.....
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    Quote Originally Posted by Egleone6 View Post
    I forget where I read it but if you remove the right headlight you can get to it pretty easily from there, which is how I replaced my OEM one several weeks ago. The grommet the pump slides into was a tremendous PITA but the pump itself was a piece of cake.
    Taking the light out also is a great way to get at the coolant level sensor.
  7. #7 Re: Windshield Wiper Pump Broke again.....
    SE Level Member f0rge's Avatar
    Nov 2008
    toronto
    not that hard, you need to jack up the front passenger side, remove the wheel, remove the fender lining and you should see the reservoir. the pump is the black thing, pop the top out of the guide (pull towards the fender, not towards the wheel) and then pull the pump straight up.
    the hardest part for me was getting the hose off the pump.
    i dont think it's recurring, the one in my GTP has worked for 11 years, but the one on my GT broke at about 60k miles.
    98 GTP - supercharged
    01 GT - turbocharged
  1. I Broke My Dash Lights :(
    By Guitarist575 in forum General Tech Discussion
    Last Post: 05-21-2008, 11:07 PM
  2. I think I broke the parking pin !
    By Meemperor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2008, 12:30 AM
  3. Broken passenger windshield wiper help
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 04-09-2008, 03:11 AM
  4. Hood release broke?
    By dunnster76 in forum General Tech Discussion
    Last Post: 03-18-2008, 08:26 PM
  5. windshield wiper help
    By maybe_memories in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 02:48 PM
