Thread: Heater issues
Results 1 to 15 of 15
  1. #1 Heater issues
    pennsylvania
    I have 97 gtp when i turn heater onɪ to two its fine when i turn it on three it gets loud and interior starts vibrating when i turn it on 5 it gets louder and vibrates more What could this be heater going out
  2. #2 Re: Heater issues
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    The way you describe it, I think there must be some garbage caught in the squirrel cage of the blower motor. Or the cage itself is fubarred.
  3. #3 Re: Heater issues
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    Maybe the engine is starting to fail...mine did that for about two weeks and then I had to change it...
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  4. #4 Re: Heater issues
    pennsylvania
    i hope its not engine starting to fail. I did hook it up to computer didnt throw any codes. WHat else did your car do before it failed like when its idling it vibrates a little bit more then it should
  5. #5 Re: Heater issues
    St. Louis
    Your engine is not failing. This is a sign that there is A. Junk in the blower motor causing it to be off-balance, or B. the motor itself is starting to go bad and is allowing the squirrel cage to flop a bit and vibrate. Let me guess, you can feel it in the pedals when its on 5 and vibrating, right?
    As far as your car vibrating more than it should at idle, when was the last time a tune-up and vac. leak check was done? I'd start there before anything.
  6. #6 Re: Heater issues
    hanover park, IL
    Just drop down the blower motor its only a couple screws holding it in. I've seen the cages crack and also cause a vibration. Id say more than likely just a blower motor. Some come with cages some don't.
  7. #7 Re: Heater issues
    Dec 2010
    Montreal, Canada
    Quote Originally Posted by FordMan77 View Post
    Hehe lol, I wasn't talking about the car's engine, but the heater engine aka blower motor....sorry for the misleading...
  8. #8 Re: Heater issues
    pennsylvania
    well when its on two its fine but the higher i go louder it gets and the sound is not in the engine its toward windsheild is that where blower motor is should i replace it
  9. #9 Re: Heater issues
    hanover park, IL
    Look at it this way..take a ceiling fan. Turn it on low it spins fine. Remove a blade or add weight to one. Now its off balance...though at a very slow speed you don't see it. Crank it up a couple notches now its all over the place.
    Remove the cover under the passenger side dash. You'll see a big black dome thing with a couple wires coming out. 3 or 4 screws hold it in. Remove those it should slide right out.
  10. #10 Re: Heater issues
    pennsylvania
    Ok what should i do after i take it out? and where is the squrriel cage thing at?
  11. #11 Re: Heater issues
    hanover park, IL
    Its attached to the blow motor. Usually white in color. Look for cracks or anything stuck in it
  12. #12 Re: Heater issues
    GT Level Member GreyGhost's Avatar
    Nov 2009
    IL
    Usually, you can drop the glove box all the way down and see the cage.
  13. #13 Re: Heater issues
    pennsylvania
    im sure its probably an easy fix or easy to replace
  14. #14 Re: Heater issues
    Dec 2010
    Montreal, Canada
    Took me an hour, in freezing cold temperature and during the night lol!
  15. #15 Re: Heater issues
    pennsylvania
    i fixed it damn bank enevlope in it dont know how the hell that got in there.
  1. 2003 Gr Prix Heater Problem and other issues.
    By kennn in forum General Tech Discussion
    Last Post: 10-27-2010, 08:45 PM
  2. Heater Issues
    By jdacosta in forum Introductions/Noob Questions
    Last Post: 12-09-2009, 07:20 AM
  3. Heater Issues
    By schoen in forum General Tech Discussion
    Last Post: 10-29-2009, 10:28 AM
  4. Backlight issues. Fan controls, Seat Heater, Temp up and down buttons.
    By Minor723 in forum General Tech Discussion
    Last Post: 01-15-2009, 10:39 AM
  5. Backlight issues. Fan controls, Seat Heater, Temp up and down buttons.
    Last Post: 01-14-2009, 10:24 AM
