Thread: Heater issues
Results 1 to 15 of 15
  1. #1 Re: Heater issues
    St. Louis
    Your engine is not failing. This is a sign that there is A. Junk in the blower motor causing it to be off-balance, or B. the motor itself is starting to go bad and is allowing the squirrel cage to flop a bit and vibrate. Let me guess, you can feel it in the pedals when its on 5 and vibrating, right?
    As far as your car vibrating more than it should at idle, when was the last time a tune-up and vac. leak check was done? I'd start there before anything.
  2. #2 Re: Heater issues
    hanover park, IL
    Just drop down the blower motor its only a couple screws holding it in. I've seen the cages crack and also cause a vibration. Id say more than likely just a blower motor. Some come with cages some don't.
  3. #3 Re: Heater issues
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    Quote Originally Posted by FordMan77 View Post
    Hehe lol, I wasn't talking about the car's engine, but the heater engine aka blower motor....sorry for the misleading...
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  1. 2003 Gr Prix Heater Problem and other issues.
    By kennn in forum General Tech Discussion
    Last Post: 10-27-2010, 08:45 PM
  2. Heater Issues
    By jdacosta in forum Introductions/Noob Questions
    Last Post: 12-09-2009, 07:20 AM
  3. Heater Issues
    By schoen in forum General Tech Discussion
    Last Post: 10-29-2009, 10:28 AM
  4. Backlight issues. Fan controls, Seat Heater, Temp up and down buttons.
    By Minor723 in forum General Tech Discussion
    Last Post: 01-15-2009, 10:39 AM
  5. Backlight issues. Fan controls, Seat Heater, Temp up and down buttons.
    Last Post: 01-14-2009, 10:24 AM
