Thread: Security Light Blinking after car is started???
Results 1 to 14 of 14
  1. #1 Security Light Blinking after car is started???
    SE Level Member nickdemio's Avatar
    STL
    Can anybody tell me why my security light is still blinking after the car is started?? but after i drive the car for awhile(atleast 30mins) it cuts off. Note: I dont have a Lock/Unlock Remote for the car! Any help would be appreciated.
    2001 GP GT
  2. #2 Re: Security Light Blinking after car is started???
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    your key is probally old and worn down and your car cant read the code on it id suggest using one of your spare keys it could also be that you un hooked the battary with the lockout on
  3. #3 Re: Security Light Blinking after car is started???
    STL
    Ok...cuz the car lot i got the car from gave me a copied key(it looks like) and they must have the original key still..just incase the have to repo it, if i miss a payment. Is there anywhere i can buy a original key for it??? or should i ask the car lot for it?
    2001 GP GT
  4. #4 Re: Security Light Blinking after car is started???
    you can search ebay for a new key but you need to know the oms of the old key so you get the right one, (oms you need to touch both sides of the chip in the key, and the reading is your keys oms), then when you get it you need to get it cut.
    i paid 9 bucks for mine, and 1 dollar to have it cut. or you could go to the dealer and pay 30 or better.
  5. #5 Re: Security Light Blinking after car is started???
    STL
    Thanx for the info guys...it was really helpful!
    2001 GP GT
  6. #6 Re: Security Light Blinking after car is started???
    STL
    I just called the GM dealership and the said the copied key i have has to have a chip in it & be programed cuz it wouldnt start if i didnt. So my next guess would be the stock alarm that comes on the car..but i dnt have the remote for it..
    2001 GP GT
  7. #7 Re: Security Light Blinking after car is started???
    Dec 2010
    Ohio
    get a key programed for it you can do it yourself if you get a key that has a code on it I did it once I forget where I found the direction
  8. #8 Re: Security Light Blinking after car is started???
    swift current,sask.
    Remember though, in 2000 if i'm not wrong they went from a resistance type system to a transponder type system.
  9. #9 Re: Security Light Blinking after car is started???
    STL
    Whiney...whats the difference between the two??
    2001 GP GT
  10. #10 Re: Security Light Blinking after car is started???
    all you need to do is search for your year car and you should be ok, most of the sellers will tel you how to figure out witch key you have/need, or hit up the dealership, but they will charge more.
  11. #11 Re: Security Light Blinking after car is started???
    Houston
    Just check your key. If it says PK3 on the key, its a passkey 3. Have a pk3 key cut and theres no need to pay to have it programmed. Just turn the car to Acc position, with your original key, for 5 seconds, take it out and put the new key in and turn to Acc position for 5 seconds. Programmed.
  12. #12 Re: Security Light Blinking after car is started???
    STL
    Thats wasup OG!
    2001 GP GT
  1. Oil Light Blinking
    By cporter1981 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2010, 12:32 AM
  2. Blinking Low Coolant Light
    By kevinpope in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-28-2010, 11:19 PM
  3. Blinking Low Coolant Light
    By EJOUIE in forum General Tech Discussion
    Last Post: 05-08-2010, 06:42 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. Blinking Low Coolant Light
    By grandprixboy in forum General Tech Discussion
    Last Post: 07-03-2009, 01:46 PM
